SRT6 Sway Bar vs N/A limited (trying to tell the difference between the two visually)
Old May 8, 2012 | 12:47 PM
frankeyser's Avatar
Default SRT6 Sway Bar vs N/A limited (trying to tell the difference between the two visually)
I purchased and installed a SRT6 front sway bar on my 2004 Limited Crossfire. When I had them both off the car and laying side by side, I could not for the life of me tell the difference. They felt like the weighed the same and the had the same tone when tapped with a wrench. I thought the Srt6 one would weight more due to the Limited one being hollow. The tail end of the Limited's part number was wore off and I could only get the Begging A170 (I think it was.) I started to wonder if the previous owner had installed a SRT6 sway bar but I purchased it in early 2006. Didn't the SRT6 not come out until late 05-06?
So I am basically asking for some help in identifying a Limited Sway bar vs and SRT6.
Old May 8, 2012 | 01:07 PM
JHM2K's Avatar
Default Re: SRT6 Sway Bar vs N/A limited (trying to tell the difference between the two visua
STR-6 sway bar = 28mm
Limited sway bar = 25mm
Old May 8, 2012 | 01:21 PM
frankeyser's Avatar
So I probably just could not see the difference. I need a tape to measure it.
Old May 8, 2012 | 02:08 PM
JHM2K's Avatar
Calipers, preferably. The difference is in the center of the bar... the ends are the same as I was able to reuse the end bushings from my Limited when I did the upgrade on my white one
Old May 8, 2012 | 02:21 PM
rayth's Avatar
does the 3mm make a big difference?
Old May 8, 2012 | 02:24 PM
JHM2K's Avatar
Not enough to rush out and buy one brand new from the dealership. But if you have the ability to obtain a SRT bar for $100 or less, it's a worthwhile mod. Very easy to swap and there is a noticeable decrease in frontal roll. Certainly cheaper than the H&R bar that is $350 for a 5mm increase.
Old May 8, 2012 | 03:59 PM
Thanks for the info, John. I was waiting to hear some real life info before trying to hunt one down, too many other things to do...
Old May 8, 2012 | 04:04 PM
rayth's Avatar
Much appreciated!
ain't that the truth
Old May 8, 2012 | 05:43 PM
frankeyser's Avatar
thanks for the info!
Kodebuster
Nov 5, 2020 04:06 PM
Roty135
17
Oct 11, 2018 10:11 AM
mopar1969
Aug 6, 2016 02:21 PM
Dave Wilson
Jul 18, 2015 05:31 PM
jwcrossfire
Jul 15, 2015 04:36 PM
