Rhythmic shake 65+ mph
Hey guys!
My crossfire just reached 100,000+ miles and running strong! I recently just replaced the brakes, rotors, and tires (mounted and balanced).
So my question is why do I have this rhythmic shake over the speed of 65+. When getting tires put on I was told that I had cracked my rear 19" wheel. Could this be the problem?
I also had a little incident with my car a few months back. My spacer (15 mm) broke and there was only one bolt holding the wheel intact, while the wheel was completely touching the wheel well. (Possibly what cracked the rim) Also the hub shield was completely touching the inside of the wheel as well.
What I'm asking for is, steps you would take if this kind of destruction happened to you. What would you likely replace after an incident like this? Shocks? Springs? Hub?
You guys are all the best, and I appreciate the security I have with my crossfire being connected with this forum! 5 years and counting!!
- Gdrag
- Gdrag
on
Re: Rhythmic shake 65+ mph
What brand/model tires did you get? I bought Falken FK 452's and had a "...thrum...thrum...thrum..." that was dependent on road surface type. It would do this on tarmac, but not on concrete. Weird. I was told by a Honda S2000 owner that his did it and the reason given to him by Honda was "a directional tread pattern sometimes does this on short wheelbase cars."
I have not heard of this from owners that keep true to the OEM Continental's the car came with-only directional tread tires.
Hope this might be an explanation.
on
Hey guys!
- Gdrag
- Gdrag
OK, did you try to mount an OEM rim/tire on the hub that went haywire? Do you have a set to mount on the axle that went south? If you do, this can eliminate all the stuff but the rim and tire. Good luck!
on
on
Mike thank you for the kind offer!
OK, so here is the latest. I just fixed the rim that was bent/cracked but still have viabration. The car was lowered 80,000 miles ago. Do you guys think its any of the joints that are causing the problem?
Or maybe wheel bearings need to be replaced?
I'd check it and the flexible disks etc that are in the drive train.
Hey OneHundred,
thanks for the quick reply!
Where is the drive shaft located? I'm a newbie when it comes to car part terms.
This is what I found from google:
03 2003 Mercedes SLK320 Driveshaft Support - Driveshaft & Axle - Vaico - PartsGeek
Where is this part located?
Wow, they need to bring back "shop class" in high school. My bet is with the wheel. Even though they supposedly fixed it, it can be way out of balance. Especially if they welded it. When welded, that added metal will throw a wheel out of balance and make it hard to be balanced again. Some shops are good at it, and some just aren't. It could also be a U-joint on the drive shaft. When worn, they will have some "slop" in them, causing an imbalance when spinning.
Ok here is the latest!
I tightened the support that seemed to be for the driveshaft and noticed a little improvement but the vibration is still there. I'm beginning to think it's my shocks? Some times the car bounces going around 25+ mph also.
What do you guys think?
quite playing with the hyrdraulic controls while driving.. or have that "fixed" wheel checked for balance...and true.
Also did you grab the driveshaft and forceably push and pull on it? You won't tear it loose no matter how hard you jerk around on it.. but if you feel it giving any then it's time to look into the connectors on it.
on
crossfireusa
10-28-2015 12:03 AM
jimf
10-10-2015 10:22 AM
grip grip
Other Cars
19
09-19-2015 08:43 PM
tritongreen
09-18-2015 07:32 AM
