Aftermarket Wheels Spacer problems
Old Aug 25, 2012 | 12:37 PM
  #121 (permalink)
Mrmiata's Avatar
Default Re: Aftermarket Wheels Spacer problems
Originally Posted by mrmiata
um.. Make me a bargain on your problem child? Lol.
Okay.. Yes they need to fix things if it's not holding air.. The tpm has rubber seals.. Wonder if "by chance" one was damaged causing your slow leak. As far as the light on the dash.. Unless your tire shop was able to "clone" the id of the replaced module.. Well bad news.. Its a trip to the dealer to tap into the main brain of the car to set it to recognize the "id" of the new module. A little dish soap/water at the valve stem will let you know if its leaking there real fast..and then if you have put it in a spray bottle use it around the wheel - tire to check the seal.
Keep us updated...
tada .. Lol
Thinking about it.. I'm kinda surprised they didn't mention programming for it when you purchased it. Dealer service above and beyond I guess..
Old Aug 25, 2012 | 03:46 PM
  #122 (permalink)
Convertible girl's Avatar
Originally Posted by Mrmiata
You"ll probably find a slow leak..
and More advice..super glue to the rescue.. LOL. Smashed my finger with a boat trailer.. "thought" I had it on the ball hitch.. slipped off and smashed my finger.. basically "blew" it open..super glue.. elect. tape.. and off to the lake.. LOL..
Well Tire and Wheel firstly checked the tmps on all four tires and originally said that the back two were not reading. After telling him the those were the last two installed, he removed the tires to gain better access and told me he was able to get them to read. As far as the front left tire loosing pressure, they took that tire off and put it at 65 psi and floated it and said they could find no leak. I told them that didn't make sense since it's definitely loosing pressure. The one guy out there was nice enough to take the tire off again and recheck it, but with the same result. I don't understand! They told me to keep an eye on the pressure and for it looking flat and to come back if that happened. HUH? Isn't that going to happen?? This is not my idea of fun
Old Aug 25, 2012 | 03:48 PM
  #123 (permalink)
tada .. Lol
Forgot to comment on your comment...I bought the car from an indivdual rather than a dealer or I'm SURE they would have.
Old Aug 25, 2012 | 04:23 PM
  #124 (permalink)
Mrmiata's Avatar
I thought you bought the sensor from the dealer? The tire "might" have had a bad seal at the rim.. backside since you did check the outside and valve stem.. 65 PSI could have been enough to force the seal at the rim.. not saying it's your case.. but when my rear tires were mounted.. they were balancing them and from the shop window I noticed one wasn't running true.. he put the weights on and all and started rolling towards the car with it.. then stopped and had noticed the bead had not seated fully at the rim.
Edit: And unless i'm mistaken in what I've read elsewhere.. a strong magnet is actually use to activate a new senor to life.. but then as noted it has to be registered to the cars computer.
Old Aug 25, 2012 | 04:31 PM
  #125 (permalink)
Default
I did buy it from the dealer but I only called to see if they had one for my car since the wheel place said they'd put it on. Had I known this was going to run ino such a big deal I would have thought to talk to the service department. Sounds like that is where I am headed anyway. The tire was sitting at 29.5 when I got home after they out it at 32 or 34. Probably 32 since its the front.
Old Aug 25, 2012 | 04:45 PM
  #126 (permalink)
Mrmiata's Avatar
Wow.. I'd be driving it right back over to them and tell them to check the pressure again.." now find the leak so we can be done here!" Soak that puppy with soapy water solution.. it's got to start blowing bubbles somewhere...
My patience would be getting a little thin at this point.. LOL.
Old Aug 25, 2012 | 05:11 PM
  #127 (permalink)
Well clearly they arent capable of finding a problem, so I might just run it back to Drivers or Discount and I'm certain they'll be happen to check it themselves for me. As of 5:10 it is sitting at 25PSI
Old Aug 26, 2012 | 10:17 PM
  #128 (permalink)
Default
I know y'all are sitting at the edge of your seats for an update to my saga for those of you not sick of it..just a little something. Tire at 13.5 psi this morning. Will have one of the two I mentioned find the problem. And then head to tire and wheel to have them fix whatever the problem is. I'll take pics of air bubbles or a statement..whatever it is with me.
Old Aug 26, 2012 | 11:14 PM
  #129 (permalink)
rayth's Avatar
Wow that's low, hope they can stop that leak!
Old Aug 26, 2012 | 11:49 PM
  #130 (permalink)
hahaha..I thought you were referring to Tire and Wheel and how they handled this situation! I'm going to contact Chrysler Corporate Office tommorrow in hopes of talking to someone who actually knows what they are talking about since everyone including the local dealer has a different take on how they work when you've replaced them. I don't know if there's some reason it's not reading correctly after relplacing the back two tpms b/c all four used to read correclty. Would lyou thnk with 13.5 psi the tire would look lower or differnt than the other ones? It didn't. I know when I took the car into a local place to do something with it, they told me that the one back tiire was reading low, but I've never seen that and I' was checking it pretty regularly. Crossifre is a unique and strange thing but I love it anyway. I just wanted to have a cool sports car that people thought I looked great driving and have fun in...little did I know.........what a challenge the car would become.
Old Aug 27, 2012 | 06:39 AM
  #131 (permalink)
Mrmiata's Avatar
Just wait till it dies on you and won't start till 20 or 30 minutes later..
But don't worry.. we can get you through it with any local monkey with a wrench.. or solder gun.. LOL.
Old Aug 27, 2012 | 03:02 PM
  #132 (permalink)
Default
The guy that sold me the wheels "Paul" told me to come back in and they would do whatever it took it get it resolved. One of the guys was saying "isnt this your third time here" and I'm like well yes it is but hopefully it's the last time for this issue. They dunked the tire again and there was no leak. Then they are rebuilt the TPMS and glued the seal around the beads...something like that. Left there and when I got home the psi was the same so it appears it's fixed, but will keep an eye on it just to be sure. Yippee! l😃
Old Aug 27, 2012 | 03:09 PM
  #133 (permalink)
Mrmiata's Avatar
Finally! LOL.. sounds like they put new seals on the TPM and maybe silicone sealant just for grins.. Now on to the dealer for the light on .. um.. don't be shocked if its a $100 date for them to program it.. Think they are in competition with Harley Davidson..
Old Aug 27, 2012 | 03:50 PM
  #134 (permalink)
That's exactly what they did. and I still need to call Chryslers Corporate office to ask about the darn tpms. Maybe, just maybe now that the tire is holding air and supposedly all four are functioning, the light will go off!
Old Aug 27, 2012 | 04:06 PM
  #135 (permalink)
Mrmiata's Avatar
Umm.. pretty big thread on TPM replacement.. thought we hit gold with Orange brand.. but nobody seems to have the T30 programmer required to set the individual wheel sensors to the old ones code.. and all street signs are pointing back to dealer for oem sensor programming. Not to mention Orange brand closed the US doors on the office here..
But do keep us updated on "phase II" .. LOL.
Old Aug 27, 2012 | 04:25 PM
  #136 (permalink)
Phase II...hahaha..very funny! Btw..you said $100.00 but I'm pretty sure the dealer I called quoted me $250.00 so maybe I need to call around. Hope that price is for all tires and ONLY if they get them to actually work! I'm going to go check out that thread though.
Old Aug 27, 2012 | 05:41 PM
  #137 (permalink)
If the light did not go out on the trip home it is not going to go out.
Old Aug 27, 2012 | 07:35 PM
  #138 (permalink)
Yes..guess so
Old Aug 27, 2012 | 09:36 PM
  #139 (permalink)
rayth's Avatar
Duct tape over the dash light!
Old Aug 27, 2012 | 09:53 PM
  #140 (permalink)
Mrmiata's Avatar
Actually electrical tape.. the black is less distracting.. Monster energy drink stickers work nicely too..
