HOW TO: Replace F+R brake rotors and pads
Old Sep 25, 2012 | 06:13 PM
Musclefan21's Avatar
Default HOW TO: Replace F+R brake rotors and pads
Well folks, I just upgraded the brake rotors to slotted and drilled rotors and threw your basic metallic pads on.
I decided to do a tutorial to help others out on this topic. I hope some of you benefit from this.
Easy job, but time consuming. I am pretty tired right now, so i guess it is also energy consuming as well
Here are the pics. She stops pretty good. I think she will stop better after a few hundred miles, once everything is broken in.
BEFORE YOU START, POP THE HOOD AND OPEN THE MASTER CYLINDER CAP, SO WHEN YOU PRESS THE PISTONS, AIR CAN ESCAPE FROM THERE.
FRONTS:
Old Sep 25, 2012 | 06:14 PM
Default Re: HOW TO: Replace F+R brake rotors and pads
REARS:
Old Mar 22, 2013 | 11:07 PM
soulintent's Avatar
Thank you so much for posting this, this being my first time the pictures and step by step instructions were a huge help. Great write up!
However, those of you who plan on doing this in the future... the wheel lug nuts are 17mm not 18mm like the picture says 18 will work for most of them but it nearly stripped a few bolts of mine i tried 17 out and it fit them all perfectly and i got them off.
Old Mar 23, 2013 | 09:45 AM
If I remember correctly, you don't have to remove the caliper to replace the rear pads.
Old Mar 23, 2013 | 10:03 AM
Whoapony's Avatar
I had to to push the pistons in since the new pads are thicker.
Old Mar 23, 2013 | 10:05 AM
32krazy!'s Avatar
Originally Posted by Whoapony
I had to to push the piston in since the new pads are thicker.
you just slide a flat tip screwdriver between the ad and rotor to push the piston inside the caliper and allow the new pads to fit
Old Mar 23, 2013 | 10:33 AM
Scratch that... I see you replaced the rotors so you must remove the calipers. Sorry.
Old Mar 23, 2013 | 01:38 PM
Thirteendog's Avatar
I'd also like to add something, don't use the clamp alone to push the piston back in. Instead place one of the old pads between the clamp and piston. This evens out the pressure and allows the piston to move back into the caliper without the possibility of jamming.
Don't forget to check your brake fluid. (If you've never changed brake fluid it would be a good idea to do that too.
Old Mar 24, 2013 | 07:01 PM
Larry Hitze's Avatar
Great pictures! Thanks
Old Mar 25, 2013 | 12:12 PM
meh03's Avatar
Thanks for posting this! I'll be doing mine soon.
Old Apr 20, 2014 | 11:26 PM
maxime75us's Avatar
Damn,
I changed the rear rotors easy but do NOt use the parking brake. If you do you will not be able to remove the rotor!
Then, I was ready to do the front. I could NOT remove the bolt that hold the caliper. The rear was easy. The front... just impossible.
If you have an idea... Please share
Thank You,
Max
Old Apr 21, 2014 | 09:26 AM
Originally Posted by maxime75us
Damn,
Thank You,
Max
I hate to admit this but I have had times when the bolts were too tight to turn, it is hard to get a good pull on the wrench when you cannot get at it properly., so I get an old wrench, as long as possible and hit the end of the wrench with a large hammer. OUCH!
A small sledge type hammer on a wrench with minimal offset is best.
It ain't pretty, but it works when you cannot get an impact gun in there.
Old Apr 21, 2014 | 09:35 AM
I use the same method as 180, except I use a lead-shot dead blow hammer.
Old Dec 23, 2014 | 10:42 AM
RyansXfire's Avatar
I found that using a 2' breaker bar with a 16 pt shallow socket allows the caliper bolts to removed easily although it only a permits small amount of rotation (up to 1/8 turn) at a time. I kept a hand on the socket to keep it seated. Work slow and watch those fingers. Total time to swap rotors/pads on both sides was about an hour and a half. With the exception of the use of a breaker bar, I followed directions found within the forum.
Old Dec 23, 2014 | 10:54 AM
You would be amazed at how fast they can be removed with an impact wrench.
Old Dec 23, 2014 | 12:37 PM
RyansXfire's Avatar
Talking Re: HOW TO: Replace F+R brake rotors and pads
The impact (pneumatic) wrench I have was too deep to fit. Can you recommend one you've found to be of an appropriate size/performance? I'm all about having the right tool for the job. Thanks for the input ala_xfire.
Old Dec 23, 2014 | 04:59 PM
I actually did somewhat like you, I broke the bolts loose with a 1/2" 3 foot pull handle, then did the rest with my 3/8" air ratchet.
I misspoke on the impact wrench part, but maybe if the wheel is turned all the way an impact can reach it ?
Old Dec 24, 2014 | 09:26 AM
RyansXfire's Avatar
Air ratchet...of course. Been a while since I used it. Forgot I had one. Time to clean out the tool chests. Happy holidays!
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
mobilefitt
Nov 8, 2015 08:30 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
Romio
Jul 24, 2015 07:04 AM
