Fitting rear shock absorbers
Old Mar 16, 2013 | 06:00 AM
wlt4674's Avatar
Smile Fitting rear shock absorbers
Hello guys,
I bought a manual '05 plate crossfire a few months ago and recently put it through an MOT - which it passed thankfully! However, the rear driver's side shock absorber was an advisory which would tie in with the clunking noise I get when going over speed bumps (of which there are lots in the UK).
My question is: how difficult is it to replace the shock absorbers if I was to buy these parts myself? Is it straight-forward job or something for the garage? My father is a pretty competent DIY mechanic so I can get a hand from him.
I assume they need replaced in pairs...
Cheers,
Warren
Old Mar 16, 2013 | 06:15 AM
Default Re: Fitting rear shock absorbers
Originally Posted by wlt4674
Hello guys,
Cheers,
Warren
Easy enough, take out the black trunk liner on both sides, jack her up one side at a time if you are using the OEM jack. Undo the nuts inside the trunk and on the suspension and you are half way there.
Replace in pairs would be best and worth the effort.
Old Mar 16, 2013 | 12:13 PM
JesseJamessrt6's Avatar
Might not be the shock making the clunking noise. Probably the best thing to try first though. When it is getting replaced check the sway bar mounts and where the mounting studs are attached. Some members have had that area crack and break causing a clunking noise.
Old Mar 16, 2013 | 07:37 PM
Bill F's Avatar
Here is the link that shows what Jessee is talking about.
Rear Sway bar brackets cracking - CrossfireForum.org
amx1397
Jan 24, 2016 02:12 PM
MAXIMUM
Aug 4, 2015 11:04 PM
ttosh
Jul 31, 2015 11:06 AM
ardenian
Jul 27, 2015 04:41 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
