Brake Repair: Altanta Area
Hey, everyone. Well, my brake warning light is coming on (2004 Roadster), so it's time to hit the repair shop. I just moved to Atlanta recently and was hoping someone here might have a good recommendation on where to take it. I brought it to Ed Voyles last fall for another issue and took it back out without letting them do the repair once I found the part elsewhere for cheaper (including labor). So, not really wanting to go back there. Any help would be appreciated, thanks in advance.
Re: Brake Repair: Altanta Area
Check you fluid level and brake pads. My guess is that you need new pads. This is easy to do yourself.
If you want someone to do it for you give Jonathan a call at Blue Ridge Mercedes. He will work on your Crossfire without a problem.
Atlanta Mercedes Repair
Buckhead imports will also be able to help. I've had work done there too.
