20 rims
Re: 20 rims
The fronts will be really tight. Tire size will make it or break it.
I run an 8" et35 and I rub when turned hard (also with eibach springs) A 9" et38 will be 10mm closer to the fender on the outside an 15.5mm closer to the strut & liner on the inside.
The rear will be 1" closer on the inside, a spacer may be required.
Power Sedan
09-20-2015 09:24 PM
tom2112
07-28-2015 08:12 AM
