Eibach Pro Kit qun...
Old Oct 23, 2004 | 12:14 AM
XFYRED's Avatar
Default Eibach Pro Kit qun...
Hi Guys...looks like I'm gonna close a killer deal on a Blaze Red/Slate 6 spd...so I'm looking to start some mods...stance especially.
Are the Eibach Pro kits for the SLK 320 and the Crossfire the same springs? Here in OZ the Pro Kit springs for the Crossfire are difficult to get...so, I'm wonderin if the MB kit is the same?
Anyone know for sure?
Thanx...
Old Oct 23, 2004 | 01:01 AM
mightyjlr's Avatar
CrossfireForum.org Founder
Default Re: Eibach Pro Kit qun...
Originally Posted by XFYRED
Hi Guys...looks like Im gonna close a killer deal on a Blaze Red/Slate 6 spd...so I'm looking to start some mods...stance especially.
Are the Eibach Pro kits for the SLK 320 and the Crossfire the same springs? Here in OZ the Pro Kit springs for the Crossfire are difficult to get...so, Im wonderin if the MB kit is the same?
Thanx...
They are the same. I have the Eibach springs for the SLK320 installed on my car.
Old Oct 23, 2004 | 01:40 AM
XFYRED's Avatar
Hey thanx for that mighty jnr....has anyone lowered their ride by 2" or more using the Eibach Sportline kit?
The pro kit specifies 1.2"...dunno if thats gonna be enough?
Did you have the Pro kit MB part number btw?
Thanx bro....
Old Oct 23, 2004 | 01:46 AM
mightyjlr's Avatar
Here is what it looks like lowered. Plenty low if you ask me:
The part number is 2552.140.
Old Oct 23, 2004 | 02:01 AM
XFYRED's Avatar
Thanx for the pix dude...but its really hard to see whether there is any fender gap present on your ride. I'm use to having my cars slammed...I figure .5" more than what you have should be OK.
BTW...they want $630 clams AUD here for the Eibach MB springs...pricey. I think I'll look up a couple of companies here that make great custom springs. I'll get the stance I'm after and cheaper to boot...
Will post pix when done ...thanx for the tips.
Old Oct 23, 2004 | 11:07 AM
Dan Root's Avatar
Banned
They still use clams for $ down under?
Old Oct 23, 2004 | 01:44 PM
andrew's Avatar
-C-I-C-C-I Associate Member
BTW....they want $630 clams AUD here for the Eibach MB springs...pricey. I think I'll look up a couple of companies here that make great custom springs. I'll get the stance I'm after and cheaper to boot...
here is my white crossfire...a tad easier to see the gap change over stock...i would say it lowered my crossfire about 2.5 inches. the eibach specs seems to be conservative imo.
i would purchase them from the "tirerack.com" for $281. i added koni shocks to mine as well.
http://www.tirerack.com/suspension/S...=all&x=107&y=7
Old Oct 23, 2004 | 11:02 PM
HDDP's Avatar
see my thread about the changes if you plan on road racing your car...
Old Oct 24, 2004 | 01:21 PM
Calif Crossfire's Avatar
Adding the kit, what does it do to the ride?
Old Oct 24, 2004 | 01:48 PM
HDDP's Avatar
If you just add the springs, it just tightens the suspension slightly and lowers the car... If you replace your OEM shocks with Koni Sport Dampers, it turns the soft rollie pollie suspension into a true, tight sportscar ride...
Old Oct 24, 2004 | 07:43 PM
Dan Root's Avatar
Banned
Question Re: Eibach Pro Kit qun...
Meaning if your kidneys are not important to you!
Does the Traction control have to be off because of your tight suspension HDDP?
Old Oct 25, 2004 | 06:26 PM
HDDP's Avatar
Not for regular driving... But on the track I routinely turn it off after my first experience with the car in that driving environment... It almost made me crash during a high speed power slide turn and tried to correct the percieved problem by sending me straight toward a wall... SASKINS had a similar experience with me a few weeks ago when he forgot to turn it off before the race, as I recommended
Old Oct 26, 2004 | 07:01 AM
saskins's Avatar
Not true! I was getting to it, I just had to find a good CD first. LOL...
Old Oct 26, 2004 | 10:55 PM
x'ed's Avatar
tc on our car cuts in way to easy, almost killed me once too driving up in the azusa mountains. the car doesnt power slide anyways, it just sticks and sticks and sticks.
Old Oct 27, 2004 | 10:10 AM
XFYRED's Avatar
Thanx for the replies guys - I think I will go for the pro kit and see how it settles down after driving around for a while.
XFYRED
Old Nov 26, 2004 | 03:38 AM
XFYRED's Avatar
Quick update...i got the same Eibach SLK 320 springs and fitted them today at a friends workshop. he was nice enough to let me use his hoist/shop.
Job wasnt too hard...but when I first got the car on the ground it was sitting a bit lower but not ny much. After driving around for an hour and udung the speed bumps to help them settle in, the car has come down nicely.
I expect the next week or two will probably drop the car bu another quarter inch or so once the springs settle in - and should look like Andrew's ride. KILLER !!
No to find the time to fab up my Magnaflow exhaust...have the muffler, ive gone with 2.5" inlet...2 x 2.5" outlets. So Ill fab it up with mandrel bends and use a resonator to knock down a few dB's and provide a little back pressure.
Widh me luck.
Old Nov 26, 2004 | 10:00 AM
andrew's Avatar
congrats! the look alone is worth every dollar spent.
cheers!
Old Nov 26, 2004 | 11:11 AM
pnsji's Avatar
If you want your car to be lowered even more, make sure you use the thinnest spring pads. In Mercedes, there are multiple different spring pads.
Old Nov 26, 2004 | 11:51 AM
saskins's Avatar
Right on Bro, HDDP just did that exact thing with the MagnaFlow. Man does it sound bitchen. I think You'll be pretty impressed by it. I know it impressed me enough to do it myself tomorrow.
Oh watch your new springs closely. I haven't touched my suspension yet, and even at stock hight, my tires rubb when I back out of my driveway
Old Nov 26, 2004 | 08:54 PM
XFYRED's Avatar
Thanx Saskins,
BTW...where are the thinner spring pads MB uses available commercially? If so, where do you get them from?
