Eibach Pro Kit qun...
You know what? I don't know. I think Chryslers eyes were bigger then there chasis. Because my tires most definitely hit that wheel well. As much as I hate it, I would never put smaller rims and tires on it.
So I'm going to the passive agressive on this one.You know the guy who complains to everyone, and does nothing about what is bothering him. I'm that guy right now.
You just go to Mercedes dealer, ask the part guy to look up the spring pad for SLK. Ask them the different part numbers.
It's like the A in the attached:
I might be able to look up the part number in my Benz EPC.
Trust me, your tires will rub if you use the Eibach / Koni combo. They will rub in three places under your front drivers wheel well when you are driving alone, making a HARD, braking right turn. And the right side will rub when you have a passenger in the car and you are making a HARD, left breaking turn. I'm talking typical sports car driving turns at 45 - 60+ mph that creates substantial front down force.
You may also experience some rub when you are turning in reverse and crank the wheel hard to the left or right.
I am running the Conti's as well. After a few dozen rubs, you'll see three little patches under your wheel well where the tire is making contact. It is on the inboard side of the tire, aligned with the inboard edge of the tread on your tire.
After quite a few days at the track and some seriously fast canton driving, I have worn down three (now highly polished) spots, all the way down to the bare aluminum. I'm afraid that if I don't increase the space by appx. 1/4" I will eventually wear right through the aluminum and shred my tire... Not good if you're doing 75mph turns with 10 other sports cars only inches away from you on a race track...
I'm looking at the possibility of stiffening the front tortion bar to limit the body roll on those hard turns, but I'm not sure that will achieve the FIX. And I'm afraid that when I go to a bit beefier RACE tire, the problem will get worse.
Although the spots under the wheel well look like they could be heated and pounded in / up to give a bit more clearance, since they are very small (about 2"w x 4"l)
I'll keep you posted...
CrossfireForum.org Founder
SLK Spring pads:
Front
A 210 321 01 84 (5mm)
A 210 321 02 84 (9mm)
A 210 321 03 84 (13mm)
A 210 321 04 84 (17mm)
A 210 321 05 84 (21mm)
Rear
A 210 325 01 84 (5mm)
A 210 325 02 84 (9mm)
A 210 325 03 84 (13mm)
A 210 325 04 84 (17mm)
Basically you can adjust the height of your car with different pads. Sometime mercedes use this to adjust the camber.
Front
Rear
If you can change pads, don't we first need to know what size we have in the XFire??? Maybe we have 5mm but if we have 21mm we could drop 2x that? = 16x2 = 32mm isn't that about 1 inch?
Amazing but true!
Mighty: The spacers were never changed from the OEM when we installed the eibachs and koni's. I don't know what difference we have in our cars but it is an issue with mine none the less. I'll try and shoot a picture the next time I have the car up on a lift.
I know it's not a weight issue as I'm barely 170lbs
xfyred:
Yes, just go to any MB dealers and give them the part number. It should be around $7-$8.
Dan Root:
Each spring has 1 pad. So changing from 21mm to 5mm will give you approximately 16mm drop. However, in the case of Mercedes, every single car comes with different spring pad settings. It's hard to generalize that every crossfire will have certain pad setting. This is why when I lower my C36 AMG versus some of my friend, even tough we both uses the exact same H&R, our drops looks different because we are using different spring pads. The thinner the pad is, the firmer your ride will be.
Dan Root:
Well I know that Mercedes/Chrysler dropped the ball when it came to my car. Because, my bone stock suspension rubs similarly to what HDDP has going on with his set up. The thing that is strange to me though is why am I having a clearance issue with the stock suspension, and no one else has noticed it until after going with different springs and shocks. Can my car just be the needle in the hay stack.
HA Ha.....Actually, the intakes are a bit on the heavy side. That only because they are made out of 16 gage steel. Those babies can take a beating, and still comes up smelling like a rose.
As far as stretching it, When I think back when I first got the car, I remember hearing a sound, that sounded like rubbing. Now prier to owning the XF I had driven chevy trucks. This was my first official car. I really didn't know what to listen, or look out for. With that outlook, I was overly careful with the car to start. So I really don't think that it was something that I had done to, or with the car to cause it to rub.
Originally Posted by pnsji
SLK Spring pads:
Front
Rear
Front
Rear
