Eibach Pro Kit Question
Old Nov 2, 2004 | 11:49 AM
xfireohio's Avatar
Question Eibach Pro Kit Question
Has anyone personally installed this kit on their Crossfire.
If so, were there any problems or hassles.
Old Nov 9, 2004 | 08:52 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Eibach Pro Kit Question
i have these springs on my crossfire....no problems here (click on link below)
https://www.crossfireforum.org/galle....php?photo=157
Old Nov 10, 2004 | 01:13 AM
HDDP's Avatar
I would not recommend installing the springs yourself, unless you are experienced in suspension work and have spring compressors etc. There really isn't much to worry about except getting it done properly, by someone who has the experience an proper tools.
I would suggest you replace the shocks / dampers at the the same time, if you have the intention of doing it in the future... Might as well kill two birds with one stone...
Don't expect to see a drop in your car for a few days to a week, until the new springs settle-in...
The Eibach springs and Koni Sport damper combination really does make a huge difference in the handling of the car...
Also, after you do the suspension job, make sure you get a professional alignment and camber adjustment, as the modification will alter both...
You'll love the true sports car feel after the changes...
Old Nov 10, 2004 | 10:16 PM
Calif Crossfire's Avatar
How was the ride after changeing them out, rough?
Old Nov 19, 2004 | 04:37 PM
Katie's Avatar
HDDP: I think the car handles superb as is, how would you rate the difference between the Koni's and Eibach's and stock? Also, I've read that the bump stops need to be shaved in order to run the springs, is this true? Or can the springs be installed without any modification?
For anyone thinking about changing the struts and springs, you might also want to consider the H&R Cup Kit.
Old Nov 19, 2004 | 06:48 PM
andrew's Avatar
i first changed just to the eibach lowering springs...no real change in ride just a better handler...lower center of gravity without any roughing to the ride. a few months later...i then added the koni's to my car...this creates a crisp rebound...e.g....when on the freeway and hitting a bump in a bridge/underpass the car settles immediately...no floating. only the "rear" bump stops in the stock shock "will" need trimmed. hope this helps! cheers.
Old Nov 20, 2004 | 05:07 PM
HDDP's Avatar
Katie: Andrew is right, I first changed the springs only and noticed very little difference. A week later I installed the Koni's and noticed a much better feel in the car. The rebound, or float, of the OEM suspension was removed. Also, there is quite a bit less understeer and body roll than the OEM system.
It becomes really noticable on the track and now handles superbly. I have raced against some stock Crossfires on road tracks here in CA. and I can hold the turns much tighter with less body roll and drift, thus giving me a better line through the turn.
If you get a chance to test drive the SRT6 at your local dealer, the suspension will feel much like the Eibach / Koni combo, only a little bit softer.
As far as everyday driving, you probably don't need to spend the money unless you are a true sports car nut. Although IMO the car looks much better with the 1.5" drop.
I wouldn't shave the bump stops especially on the front as the drop will cause clearance issues with your front tires rubbing inside the wheel wells on hard braking turns. Especially if the driver is 200lbs.
Good Luck,
Old Nov 20, 2004 | 06:03 PM
Dan Root's Avatar
Banned
hey... hddp did you give up on the SRT6 ?
Old Nov 20, 2004 | 06:20 PM
HDDP's Avatar
Nope, the SRT6 is still on order. No delivery date as of yet... Was ordered in July... Go figure !!! I'll be collecting Social Security at this rate...
Old Nov 22, 2004 | 02:51 PM
mjanowich's Avatar
So, if I didn't want my car lowered and wanted better handling, would you recommend just the Koni Sport dampers?
Old Nov 26, 2004 | 12:26 AM
pnsji's Avatar
What is the color of the eibach springs? Because I don't want the dealer to find out that I put aftermarket springs and void my warranty. Otherwise I will just paint them black!
black in color and powered coated. they look as stock.
Old Nov 26, 2004 | 10:03 AM
andrew's Avatar
pioneer4x4
Mar 18, 2021 02:17 PM
Nexxus
May 8, 2016 04:43 PM
ayebb
Sep 18, 2015 03:35 PM
Sep 13, 2015 02:12 AM
Big Daddy
Sep 10, 2015 10:21 PM
