19x10 or 19x10.5 wheels
Old 05-12-2014, 05:22 PM
Speedy4x4's Avatar
Default
I have been spending weeks trying to find wheels with no luck. So know I asking you guys and gals for help please please please.
18x8.5 front
19x10.5 or 19x10 rear
Silver preferable
With lips or dished NOT flat faced.
And less than $1,000 per wheel.
Any suggestions please.
Old 05-12-2014, 05:59 PM
Squirrel Crusher's Avatar
Default Re: 19x10 or 19x10.5 wheels
Check out MHT Paragon Z 184 wheels. Squirrel Crusher
Old 05-12-2014, 07:38 PM
Speedy4x4's Avatar
Default
They do not make the 18" for the front
Old 05-13-2014, 06:53 AM
Speedy4x4's Avatar
Default
Every time I find 19x10's either they do not have matching 18" fronts, do not come in our bolt pattern or they ate flat faced ;(
Old 05-13-2014, 07:59 AM
those 19x10's are gonna be hard to find.
maxcichon has Stern wheels, they look pretty sweet and you can do all 4 for < $1000
( you will have to settle for 19x9.5 however )
ST-1 :: STERN WHEELS :: WHEEL :: MaxSpeed Performance
Old 05-13-2014, 08:41 AM
Speedy4x4's Avatar
Default
Stern are steel wheels and only the St comes in a 19x10 and the st6's look like they would have lots of wheel flex at cornering. If I went with 19x9.5 I would go touren tr5's. But I like the wider tires on the back so a wider rim will flatten out the tread a little more and a wider rim gives less sideways tire roll. Too wide of rim for tire and you will get less playability in tire and make a stiffer ride.
I really like the look of the touren tr5's just wish the came bigger then 19x9.5
Old 05-13-2014, 07:50 PM
Speedy4x4's Avatar
Default
Please help. I Just spent 2 hours at a wheel shop finding not a dang thing unless I want flat faced or only 9.5's on rear. Suggestions anyone please?
Old 05-13-2014, 08:24 PM
Mrmiata's Avatar
Mercedes Wheels | Mandrus
Correct hub bore etc..
Old 05-13-2014, 08:31 PM
Speedy4x4's Avatar
Default
But mandrus only goes up to 19x9.5 no 19x10 or 19x10.5
velociabstract's Avatar
STR 610 GLOSS BLACK | STR RACING
I don't know if they have the correct hub bore.
Les
Old 05-13-2014, 08:38 PM
Speedy4x4's Avatar
Default
Those are flat faced. I Found a few with the size I want BUT they are flat faced rims. I want a lip, not a fan of flat faced rims
Old 05-13-2014, 09:04 PM
Mrmiata's Avatar
Get your wallet out and head to here..
Lexani Custom Luxury Wheels
Old 05-13-2014, 09:10 PM
Speedy4x4's Avatar
Default
I not going to spend $1,000 per wheel. I also looking for a good 10 or 10.5 in a 114.3, 120 etc. Pattern with a 40-45 offset and use a 20mm adapter would hate to but trying to find something
Old 05-14-2014, 11:12 AM
rayth's Avatar
I think the Brabus Monoblocks come in 10" wide..
I see Niche wheels popping up a lot and they have a few that come in workable sizes/offsets.. not sure about their quality though
http://www.nicheroadwheels.com/cms_p...1%20Targa2.pdf slight concave with a stepped lip..
here's something interesting for you as well: ?|? Rotiform Wheels ?|?
SSR also has some options: SSR Wheels - SSR Executor EX02
Old 05-14-2014, 11:40 AM
maxcichon's Avatar
I hate to even suggest it, but have you entered this in an eBay search:
19X10 5X112
If you find something you like-contact the seller to see if he is willing to mix-n-match a set you like.
Worked for me.
Old 05-14-2014, 12:19 PM
xme's Avatar
xme
xme is offline
That's a pretty specific request on a car where, in my humble opinion, we already have somewhat limited wheel selection unless you're willing to use spacers. I think if you're willing to budge on the staggered sizes and go with 18" all around, or 19" all around you're going to have a lot more luck fulfilling your other requirements. If you're willing to go with 19s on the front and 20s on the back STR 607s come in 19x8.5 and 20x10, but I'm not sure what the center bore on those is...
Old 05-14-2014, 02:14 PM
Speedy4x4's Avatar
Default
I like the 18/19 for this car and since I in it 2-4 hrs twice a week did not want to decrease the sidewall. I have found a few sweet looking options for 19x8.5 20x10 with lips. Not just wheels we are limited on ALOT with the MB.
Old 05-14-2014, 02:21 PM
cg80's Avatar
As Mrmiata said."get your wallet out and head over here"...Lexani...I purchased 4 19" staggered (8.5 front & 9.5 rear) Gloss Black Machined Faced rims about 8 months ago...really like them... approx. cost 1500.00. and since viewing their new selection, I see more "wheel Candy" that would be sweet... Carl
Old 05-14-2014, 02:22 PM
Speedy4x4's Avatar
Default
19X10 5X112
Worked for me.
Been doing that and looking at corvette 19x10.5 5x120.7wheels and use a 20-25mm adapter.
Thought I had a winner and got excited with the new 2014 tsw Monaco's with 18x8.5 5x112 and a 19x10.5 5x120 40mm offset and use the 20mm adapter was at a wheel shop he double checked he specs for wheel in his book & online and said that was right. As he called in to order them they told him the 10.5 only comes in a 27 offset not the 40 that was showing online. ;(
Old 05-14-2014, 02:28 PM
Speedy4x4's Avatar
Default
I have found plenty in 19x9.5 that are great wheels.
If I went 19x9.5 they would be
http://rims.wheeldealsdirect.com/4368/Touren/TR5
I really like the looks of those and have had wheel shops tell me they are a really strong and light wheel.
Quick Reply: 19x10 or 19x10.5 wheels
