Where or what to buy? Rear anti sway bar bushings for an `05 limited
Old Nov 15, 2014 | 10:00 AM
six banger's Avatar
Default Where or what to buy? Rear anti sway bar bushings for an `05 limited
I`ve been searching the forums and perhaps I`m using the wrong key words. I`ve found threads on poly rear bushings but most seem to be for the srt-6. And the ones I did find for the limited, don`t seem to know what the diameter actually should be? I tried ordering OEM off a vendors site and apparently they are no longer available.
My bushings are worn, and the sway bar is loose, and info would be appreciated.
Thanks!
Old Nov 21, 2014 | 03:41 PM
DTMenace's Avatar
Default Re: Where or what to buy? Rear anti sway bar bushings for an `05 limited
Thanks!
six banger
Click on the link below, it will take you to the Mercedes SLK320, which has the same parts as your Crossfire Limited model. Scroll down on the left hand side and click on the suspension and go to the specific part you are looking for your car. This is the lowest prices for parts....
Dennis
DTMenace
OE Discount Parts
Old Nov 21, 2014 | 09:35 PM
six banger's Avatar
Thumbs up Re: Where or what to buy? Rear anti sway bar bushings for an `05 limited
Thanks, I appreciate your help! I just ordered them up, I`ll let you know if they are available that way.
Old Nov 25, 2014 | 08:57 AM
six banger's Avatar
Unhappy Re: Where or what to buy? Rear anti sway bar bushings for an `05 limited
Unfortunately these bushings are discontinued everywhere, including Chrysler, and it doesn`t appear any aftermarket companies, (Energy Suspension, ect.) carry them either I can`t believe I`m the only one with this issue. I`ll continue my search and if anyone else knows where some may still be lying around I`d appreciate it. I believe now the only possible option I have is to change out my bar, an expensive fix for a minor problem...
Old Nov 25, 2014 | 09:38 AM
Bill F's Avatar
Did you try here? Prothane 19-1105 Dee Engineering Sway Bar Bushing | Auto Parts Warehouse
Old Nov 26, 2014 | 12:33 AM
six banger's Avatar
Bill,
No I haven`t and thank you I will. My son has had the car and I haven`t had the time to go out and measure the diameter of the bar, and then I wasn`t sure if it was in inches or millimeters. So I`ll assume you are confident these are the correct ones, and order them up. thanks for your help!!
Old Nov 26, 2014 | 08:32 AM
Bill F's Avatar
Bill,
Not sure, but it says will fit the MB SLK 320. Note: This part may require customization to fit your vehicle.
Old Nov 26, 2014 | 10:00 AM
I measure the rear sway bar on my NA roadster at 18.25 MM, if that helps.
Kodebuster
Nov 5, 2020 04:06 PM
Roty135
17
Oct 11, 2018 10:11 AM
amx1397
Jan 24, 2016 02:12 PM
Buchacho
Jul 9, 2015 04:13 PM
GWAPA
Jul 8, 2015 07:25 PM
