Overall information for suspension and camber
Old Jul 19, 2016 | 03:11 PM
ShufStiX's Avatar
Cool Overall information for suspension and camber
Hello, I was crawling the Internet and the forum to get information on camber mods and suspensions options we have for our cars and the lowering possibilities. I thought I would gather all the info in one post so for the others who come later doesn't have to read every single thread.
I'm not a expert so if I'm wrong at any point don't hesitate to point it.
I'll dive this post 3 parts :
1 - Camber solutions
2 - shock and springs
3 - Coil Overs
1 : Camber solution
While searching I found out that the only thing you can play with on the R170 base is at the front for alignment and at the rear can't. The OEM bolts offer to little to adjust, the easy solution is to replace those 4 bolts with : Febi Bilstein 7752 bolts 7$ each. The more advanced and expensive solution would be to get the K-Mac front adjustable camber kit. :
Chrysler Crossfire (2004 - 2008) Front Camber & Caster kit #502016 J - K-Mac Suspension
Some people would say it's a reliable option and others says its crap ( source MB forum )
As for the rear camber stock they can't move a inch. So there are several upgrade options.
1 - K-Mac rear camber adjustable kit as costly as the front they offer a wide alignment solutions :
Chrysler Crossfire (2004 - 2008) Rear Camber & Toe kit #502026 H - K-Mac Suspension
2 - Ground Controll adjustable suspension components, the full kit is 1k$+ but offers unlimited configurations. :
NeedsWings Performance Products. Ground Control Adjustable Rear Components
3 - Meganracing rear adjustable camber 180$
2004-2008 Chrysler Crossfire Rear Camber Kit Control Arms : Megan Racing
4 - MBarts rear adjustable camber 330$
MB Arts - Adjustable Rear Toe Links (R170)
5 - eBay Toospeed rear camber 200$ ( I don't recommend it )
Mercedes Benz R170 SLK-Class 98-04 Adjustable Rear Camber Arm Arms | eBay
6 - The egmcartech solution
Mercedes Benz Rear Adjustable Arm Camber Kit W201 W202 W203 R170 W208 W209 W210 for Sale - emgCarTech
7 - The DIY solution which can be found at this link : https://www.crossfireforum.org/forum...tml#post714875
Or this link
https://www.crossfireforum.org/forum...r-cambers.html
2 - Shocks and Springs
This section I won't detail everything since shocks and springs is wide and can be personalized in many way for example Koni with H&R springs or Eibach etc etc.
But I will list some most popular combination kits that are available.
1 - Koni
https://www.koni.com/Cars/Products/L...mt=1&modelt=10
2 - Ground Control
Ground Control - Street and race suspension systems for your car!
3 - Bilstein
CHRYSLER CROSSFIRE 3.2 Bilstein B12 Pro Kit Suspension Kit 46-000682 Only £515.91
3 - Coil overs
So this is the best of the best you can get at suspension upgrade but is also a bit more costly. There is low end until high end solutions I will list some in here to get a better overview of the popular stuff
1 - KW V2 coil overs between 1500$/2000$
KW automotive GmbH - Gewindefahrwerke, Rennsportfahrwerke, Sportfedern - KW Coilover Variant 2 inox
2 - Bilstein B14 / B16 coil overs ( which I prefer over the KW ) between 900$/1800$
Bilstein Chrysler Crossfire SRT-6 B14 Coilover, Bilstein-Shop.com
And
Bilstein Chrysler Crossfire 3.2 B16 PSS9 Coilover, Bilstein-Shop.com
3 - BC Racing ( low end )
BC Racing BR Coilovers Chrysler Crossfire
Of course this list is not exhaustive. I hope it helped if got anything to add or to correct please shoot ahead.
I'll try to help as much as I can
Johnny.
Old Jul 20, 2016 | 06:38 AM
daveesrt6's Avatar
Default Re: Overall information for suspension and camber
Thanks for this, good job !
Old Jul 20, 2016 | 06:41 AM
ShufStiX's Avatar
Your welcome, I was confused myself so I decided to write everything down and then I thought I'll make it a post ��
Old Jul 29, 2016 | 09:06 AM
zip439's Avatar
DITTO! I'm going to print & save your post for future reference.
C-Note
27
Aug 15, 2018 06:20 PM
KnappAttack
Jul 1, 2016 06:33 PM
dedwards0323
Jun 3, 2016 12:59 PM
Buchacho
Apr 23, 2016 12:28 PM
