Aftermarket TPMS
Old Feb 27, 2017 | 07:11 PM
Jocko124's Avatar
Default Aftermarket TPMS
Does anyone have experience with an aftermarket TPMS system that could relay actual wheel pressure to a smartphone or separate monitor---such as SteelMate?
Old Feb 27, 2017 | 08:19 PM
Speedy4x4's Avatar
Default
I have a tpms I got off amazon, shows pressure and temp, but temp is c only, they are external sensors.
Which means it is the valve cap, no need to have a tire shop to install, and have a display mounted inside.
Old Mar 3, 2017 | 11:45 PM
Default Re: Aftermarket TPMS
Do you have to take the sensors off to add air to the tires?
Old Mar 4, 2017 | 02:42 AM
turbomar's Avatar
Yes, external tpms consists of 4 transmitting caps and a dash mounted receiver display. Probably not as reliable as OE but gives you more info. Very cool and affordable!
external tpms | eBay
Old Mar 4, 2017 | 07:22 AM
Speedy4x4's Avatar
Default
Yes, have to remove to add air to tire.
Also when battery is dead, you can change battery yourself. Instead of paying a shop.
Keep some spare batteries around, they are cheap if bought on ebay, $2 apiece buy 3 get 2 free, energizer lithium, $6.50 apiece in town.
Definitely worth it for me to see the exact pressure.
They have been working good for me, has a warning light and alarm when a battery is low on sensors.
If anyone pulls trailers and has had a blow out on a trailer and k ow that pain, there are also setups for trailers and trucks and trailers, a booster antenna is added so the monitor can get the data from the senor farther away on trailers.
Old Mar 4, 2017 | 09:42 PM
Something to keep in mind. Thanks. But I would prefer psi readings. James
Old Mar 4, 2017 | 09:54 PM
Speedy4x4's Avatar
Default
Some also use apps on phone instead of a display screen.
I wanted the screen.
Old Mar 5, 2017 | 12:02 PM
Jocko124's Avatar
Which brand/model is it?
Old Mar 5, 2017 | 12:54 PM
I see that at least some of these give readings in BAR and PSI, you choose in the set up. That plus temp is probably more than required but ...
They look a bit clunky and you probably need a wheel balance if you are particular about added weights on wheels.
Me I'll stick with the OEMs a little bit longer.
Old Feb 16, 2018 | 09:37 AM
zero4crossfire's Avatar
Amazon Amazon
Old Feb 25, 2018 | 08:42 AM
Amazon Amazon
