Rotex Install Help
Old Jun 24, 2005 | 02:51 PM
FerrariVdub's Avatar
Default Rotex Install Help
Haven't posted in a while but gonna need some help today. I bought a set of Rotex for the fronts. I want to take off the rotors to be shaved down. I saw some install posts, just had some questions. How easy is it to take off the rotor once I have taken off the caliper from the rotor? Is there anything special I should do, or know before doing this job? Any reply of links would be greatly appreciated.
Old Jun 24, 2005 | 09:44 PM
Dan Root's Avatar
Banned
Default Re: Rotex Install Help
the rotor pulls off easier than the caliper.
Old Jun 24, 2005 | 10:07 PM
former NXMX5's Avatar
its pretty easy, remove the caliper (two allen key bolts and the wire bracket), and then remove the caliper bracket (two larger bolts, 17, 18mm IIRC). Then there is a philips head screw holding the rotor on, just unscrew it and the rotor should come off. good luck.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
