ABS light - throwing no codes???
Old Feb 22, 2020 | 04:50 PM
Cotyt94's Avatar
Default ABS light - throwing no codes???
Hooked it up to my buddys scanner that will do ABS.... Still no codes? We got into the computer.... Any ideas? Where are the fuses?
Old Feb 22, 2020 | 05:31 PM
Default Re: ABS light - throwing no codes???
Have you tried doing the reset? Start the car, turn the steering wheel all of the way to the right then all of the way to the left and then back to center. Shut off the engine and restart.
Old Feb 22, 2020 | 05:58 PM
Cotyt94's Avatar
Thats steering angle reset? Just tried it no bueno
also replaced fuse # 31. It was shot. Didnt fix anything though
Old Feb 24, 2020 | 08:39 AM
zip439's Avatar
Brake light switch, under the dash, top of peddle?
Old Feb 24, 2020 | 09:54 AM
Cotyt94's Avatar
hmm, ill have to check... I did have that panel dropped cuz of SKREEM. The ABS light didn't come on until after i monkeyed aroundwith the tcm ecm though
Old Apr 27, 2020 | 11:49 PM
Cotyt94's Avatar
Update - ABS turned off on its own after fresh tires, or me using the traction control switch for the first time since the codes were thrown
Delcobob
Jun 21, 2017 03:03 PM
Delcobob
Jun 15, 2017 09:57 AM
fire in the hole
May 17, 2017 11:16 PM
2005 Ragtop
Aug 20, 2014 03:38 PM
SRT6_Roadster
May 1, 2011 09:00 PM
