Emergency Brake
Old May 30, 2022 | 02:37 PM
Dschnbgr's Avatar
Default Emergency Brake
Yesterday I was driving my ‘05 SRT6 when it appeared as though my brakes were suddenly dragging and I was getting smoke from both rear tires. I stopped to let them cool and didn’t note anything visually so I dragged it the last mile home. This am I tried to remove my rotors and they were hung up on the emergency brake shoes that hadn’t fully retracted. That was apparently my problem yesterday.
The handbrake seems to operate normally but the shoes do not retract. Is it linkage, have to replace shoes or…?
Thanks as always!
Old May 30, 2022 | 06:34 PM
Default Re: Emergency Brake
Thanks as always!
If you do not use the emergency brake often the cable can seize up inside. As to the shoes, only you know what state they are in. Did the top hat get scored ? Or did the rotor get warped?
Did you use and forget the hand brake was on or partly on?
I occasionally use the handbrake just to keep it in shape, mostly on hills.
RockAuto
Sep 22, 2020 11:03 AM
soulintent
Mar 20, 2013 03:15 PM
tom_vb
17
Jun 16, 2010 07:19 AM
crossfire2006
Oct 30, 2009 12:39 PM
tony sortino
Dec 2, 2006 06:20 PM
