Larger Tire Aspect Ratio
Old Jan 20, 2023 | 03:13 PM
Romad's Avatar
Default Larger Tire Aspect Ratio
Has anyone gone to a larger aspect ratio tire to enable a smoother ride? The factore 255/35's are, to me, a little too rough a ride. Especially when you hit small bumps and pot holes. Say maybe a 255/45r or 255/55r tire!
Old Jan 20, 2023 | 05:17 PM
DTMenace's Avatar
Default Re: Larger Tire Aspect Ratio
Romad
There is an alternative to the Crossfire tire setup, you should have bought a MB SLK320 (2000-2004) from Mercedes Benz, since those models were equipped with 16" wheels and had 55/60 aspect tires, lower spring rates, which provided a "softer" ride. The SLK32 had 17" wheels with similar aspect tires from the factory for a softer ride, since it was considered upscale product vs. the Crossfire models.
When you bought your Crossfire, did you happen to road test the car over various surfaces? When did you decide the ride was too rough?
If you used the SEARCH button at the top of the main page, about taming the rough ride, this was discussed numerous times for the past 20 years.
Why did you buy a short wheel based sports car and expect a luxury, soft ride?
Just my 2 cents....
Dennis
DTMenace
Old Jan 21, 2023 | 09:02 AM
Romad's Avatar
Originally Posted by DTMenace
Romad
Just my 2 cents....
Dennis
DTMenace
Because it saw me, I saw it and it was "love" at first site. It's only a rough ride when driving over brick laid roads, pot holes and sewer man hole covers! Why buy a SLK320 when you can have a Crossfire! LoL
Old Jan 21, 2023 | 11:55 AM
I concur with DTMenace above. You probably won't get much sympathy from anyone on trying to make the ride in the Crossfire softer. But you're not alone in saying the Crossfire ride is somewhat harsher than you expected. But I think I remember someone verifying that the maximum tire/wheel diameter the Crossfire could take was 27 inches (685 mm). The tires you're suggesting exceed that figure if you are going to use the OEM wheels. You will probably have to go narrower with the tread width to find something that works. (Note: A 235/40x19 should work, but I'm not a fan of going narrower on the tire. You will need to verify that the narrower tire will work on a 9" wide rim like the Crossfire has in the rear.) But if you use that 685 mm figure, you could shop around to look for a combo that would address your desire. But I don't think you will have many options. Others may chime in on this. Your options are better if you want to include smaller aftermarket wheels or find another pair of Chrysler 18" wheels for the rear - some owners have done this for a variety of reasons (e.g., tire rotation, etc.)..
You can use this link to compare OEM to aftermarket wheel/tire combinations. CLICK
Old Jan 21, 2023 | 03:48 PM
copperfieldkid's Avatar
Romad, regarding your larger aspect ratio tire question, here is a link that will provide additional information for your consideration. There are limitations to improve the ride. Certain shocks, tires, but the short coupled Crossfire is the major reason for the wash-board ride (depending on the surface) Keeping your gas tank full increasing the weight also helps. (A gallon of gasoline weighs roughly 6 pounds). Keep in mind it IS a sports car.
wheel_stuff(1).xls
(Click the 'skip sign in...' then close out the Mico-soft banner page and you have full view of chart)
Old Jan 21, 2023 | 04:01 PM
"There is an alternative to the Crossfire tire setup, you should have bought a MB SLK320 (2000-2004) from Mercedes Benz, since those models were equipped with 16" wheels and had 55/60 aspect tires, lower spring rates, which provided a "softer" ride. The SLK32 had 17" wheels with similar aspect tires from the factory for a softer ride, since it was considered upscale product vs. the Crossfire models."
No, the absolute best buy would be a 1954-1957 MB 300SL Gullwing
Old Jan 21, 2023 | 04:02 PM
Romad's Avatar
wheel_stuff(1).xls (Click the 'skip sign in...' then close out the Mico-soft free trial banner page and you have full view of chart)
So was my '90 Miata but smaller wheels and bigger aspect tires.
Old Jan 22, 2023 | 08:48 AM
Here's a Post that gives you tire/wheel options for the Crossfire: CLICK
AlG
May 14, 2008 08:03 AM
Veree
Feb 23, 2008 08:43 AM
jackei
Feb 17, 2008 09:15 AM
willie
Nov 1, 2004 02:30 PM
garmin
Mar 29, 2004 09:03 AM
