How do I check Transmission Fluid level?
Old 09-20-2007, 08:26 PM
banej's Avatar
Default How do I check Transmission Fluid level?
i just got my crossfire recently and just cannot find a way to check my trans fluid level. how do i do it ? do i have to take it to the dealership? how much does it cost to check if car not under warranty?
Old 09-20-2007, 08:41 PM
+fireamx's Avatar
Default Re: How do i check Transmission Fluid level?
The easiest way to check your tranny fluid is to just look under your car for puddles. If you don't see any, then it's probably OK.
Without a dipstick, the factory must have alot of confidence in it. So there probably isn't much to be concerned about.
Old 09-20-2007, 08:44 PM
banej's Avatar
its kinda stupid the way they made it. the reason i want to check it is because im not the first owner of the car and i purchased it with 30K. i just wanna be safe and check it somehow but i wish i knew a way to do it.
Old 09-20-2007, 08:58 PM
+fireamx's Avatar
I agree, I think it's a German thing. I got my wife a new 1998 Beetle, and even though it was a stick, I noticed in the owners manual that their trannys didn't have dipsticks either.
Old 09-21-2007, 04:22 AM
CrossfireLTD's Avatar
Cool Re: How do i check Transmission Fluid level?
The tranny is sealed at the factory for life, you would need to purchase a "Special Service Dipstick Tool" (part #8863) and a funnel (part #8908) if you need to fill the tranny. This info was taken from the "Crossfire Training Reference Manual" and can be found on pg. 195. The NAG-1 automatic transmission takes 10.57 qts. (10 liters) and uses MS-9602 ATF+4 Automatic Transmission Fluid.
Old 09-21-2007, 03:09 PM
Iamfink2's Avatar
The owners manual states change automatic transmission fluid and filter at 80,000 miles then this is for the life of the car.
Old 09-21-2007, 05:48 PM
I also so that in the Owners Manual...I will question my Tech the next time I am at the dealer.
Old 05-04-2011, 05:42 PM
silverfish1's Avatar
Banned
Angry Re: How do i check Transmission Fluid level?
Good luck dude---there is no trans dip stick you need to order one
and finding one is a pin in the aas
Buy a Jap car
Old 05-04-2011, 08:27 PM
ChuckNorris's Avatar
I made a dipstick out of a manual choke cable(about $10 at auto store). All I did was remove the solid wire from the center and use the flexible conduit. I painted about 4 inches of one end white and made marks where the level should be. You can also use an extra long zip tie like Woody did. I posted the exact measurements for the markings on a thread on here somewhere...
Old 05-04-2011, 09:08 PM
glad i saw this, i just bought mine a couple of months ago and didn't even notice till the other day that the dipstick was missing or i thought. my charger doesn't have one either. mine is missing the cap though, what the crap.
Old 05-05-2011, 09:50 AM
Banned
Default Re: How do I check Transmission Fluid level?
Can you give me measurments from end to end how long should this cable be?
4 feet 4 inch? and the end needs to be 3' 1/4 long
Old 05-05-2011, 10:25 AM
MikeR's Avatar
Silverfish,
I find it hard to understand how you can't figure this out with all the info you have been pointed to. The total length of the transmission dip stick doesn't make any difference as long as you are holding one end and the other end is at the bottom of the transmission. The Miller tool is 52" long. The measurement section is about 80mm/3" with markings every 10mm. See pics and previous data pointed out to you. To measure the fluid properly you will also need an infrared thermometer to read the temp of the transmission sump. I hope this settles all of your questions...
Its markings at 25 degrees Celsius ATF temperature range between 10.3mm to 21.3mm.
At 80 degrees Celsius ATF temperature they range between 54mm to 65mm.
As pilfered from your service manual:
Old 05-05-2011, 11:43 AM
Banned
Finally Pics- thanks so much--- i assume i can use a choke cable that would allow me to messure the Trans oil.
Most places will not do a trans drain and fill cause the car does NOT have a dip stick, Nor will they drop the pan ....so im doing it myslef.
Thanks again Very helpfull
And rem: Dont fake the funk on a nasty dunk!!!
Old 05-05-2011, 12:22 PM
Banned
Cool Re: How do I check Transmission Fluid level?
Dumb question but is that 52' from top to the very end of the meauring device tip?
Thanks again
Old 05-05-2011, 04:47 PM
MikeR's Avatar
If you make it 52' you will have about 47 1/2 feet to play with........
Old 05-05-2011, 05:06 PM
arejohn's Avatar
I have a question about the temp/mm chart. Is the distance from the bottom of the pan or the bottom of the factory stick?
I don't believe the manual states "life of the car." More like filled for life or lifetime fluid. "Lifetime" being life of the warranty.
And while we are servicing transmissions, how can the leak free transmission cable plug be identified?
Old 05-05-2011, 05:22 PM
See post#12
From Manual.
Change filter and fluid at 80,000 miles. The fluid is then filled for life.
It can be identified by no leak being visible.
Old 05-05-2011, 05:42 PM
arejohn's Avatar
Thanks, now I can cross off all those tranny parts from my autohaus list and spend it on.....on.....oh ill remember in a minute.
Old 08-20-2016, 02:16 PM
If you "fill for life" that means your transmission will eventually DIE because you didn't change the fluid or the filter. These cars are known to drive for 300,000 miles with proper care, so if you stop maintenance at 80K miles, I would have to presume you want its life span to be shorter than 300,000 miles. It's up to you. As for me, if I still own the car in another 60K miles, I will change the fluid and filter again in MY car.
Old 08-20-2016, 10:30 PM
Answering a five year old post, better late than never.
Quick Reply: How do I check Transmission Fluid level?
