Burning rubber smell
Re: Burning rubber smell
Originally Posted by MikeR
You can drive it with no worries. The gasket is an RTV like material and they will pull the small cover, clean it all off, re-apply new gasket material and bolt it back on. After a few hours it is as good as new (or better). You should check the one on the passenger side also. It may have a slow/small leak also.
Can someone please answer my question? Also, is this "RTV" material you are referring to readily available at the dealership or will I need to bring the car back?
The bad news is my Xfire did not pass the emissions part of the inspection because the car doesn't have enough miles I was told to drive it about 50 miles with a combo of highway and stop-and go and bring it back.
Imperial4ever,
Did you have any oil drops on the ground? Where is the valve cover anyway? I need a diagram... I have noticed very faint burnt smell once last week and again this week, only when cold started the XF and when I have driven a hundred yards or so. Both times, the smell went away after a minute or so of driving. I wonder if I have the same problem. Mine is also an 08.
Originally Posted by BlazingSaddle
Imperial4ever,
Originally Posted by IMPERIAL4EVER
Thankfully, no oil on the ground. I do not have a diagram. The valve cover lies underneath the engine cover. The burning smell went away after a few miles most likely because the oil has burned off of the manifold. The best thing would be to take it in the dealership.
btw: Anyone interested in purchasing a 2008 Crossfire with 250 miles on it and never been rained on or driven on wet/salt covered roads? Will sell it for what I paid $22,500.
This post is a bit old but just in case anyone comes along
in the future, I would like to add that I also had the
burning rubber / Plastic smell from under the hood
or the front vent. When Idle or parked after a trip
and it was in fact a valve cover gasket fix.
The oil would leak and burn off causing the smell
I would even get a small amount of smoke visible best at night
and by illuminating slowly with a flashlight around or under the spark plug area the smell is pretty strong you cant really miss it.
The problem can either be on the passenger side or driver side each side needs a gasket and they are both different size / shape
in my case it was the passenger side. So I only needed to replace
the passenger side
The gasket for the passenger side was about 20$ got it online and my mechanic charged me 55$ to replace it, it took about 30 min, . No problems no stinky smell either after fix all was fine
Good luck!
the passenger side
Good luck!
o55ie18
10-05-2015 05:50 PM
tritongreen
09-18-2015 07:32 AM
