High pitched electric motor noise from rear
It is very loud and on all the time. I noticed that when I turn the key on, the noise starts, but then the engine starts.
Is it the fuel pump? Is it because the gas tank is almost on empty?? Where can I find info on how to change out the fuel pump?
Thanks all. -- Oh, and I combed through over 12 pages of threads but didn't find any useful info.
Re: High pitched electric motor noise from rear
Can you explain your thinking behind this?
(A) External pump so "cooling" is not a factor..
(B) most cars I've seen pull fuel from the bottom of the tank.. where any sediment is already there.
Water is a different story.
on
Usually a bad idea to keep less then 1/2 tank over a long period of time since temperature changes causes moisture to condense in the fuel tank (and we all know water in the tank is not good). Keep listening, you MIGHT have a foaming issue from the return line or somewhere else. If you do, when the fuel pump catches that foam, it'll cause the pump impeller to spin much higher and starve the rail (if a long enough duration). Don't 'crazy' on it, just keep a listen for it repeating itself. If it does it with 1/2 tank of fuel, you need to look for its cause. Good luck, and have fun cruising!
