Traction Control
Traction Control
I have had my lowers dash panels out, and my console apart, to remove the carpet, in preparation for welding in a roll cage, and after reassembling the dash, I took the car out and hammered it a few times, with the traction control off and on. With it off, it ran hard a couple of times but several times it had no power starting off, but would sometimes explode after getting the revs up, or pedaling it a little bit. It was inconsistent. Almost like starting out in third gear, but it was in first. I need some help from you brilliant guys. It has explosive power when it comes to life. Thanks!
Re: Traction Control
PS: My car has a Eurocharged tune in it, and I noticed another post that mentioned that the winter summer switch controls manual vs. automatic shifting. I had the switch in S, so maybe that contributed to my erratic shifting or feeling that it was starting out in a higher gear. Although, as I understood the other post, it should have been in full automatic mode. It still seems like a traction control problem.
The intercooler pump is working. One time I start off it has no power, and if I play with the accelerator a little bit, it comes to life in a really big way. Its almost like its in limp in mode, and then it blasts off. I had the dash apart, and I may have screwed something up.
Robert. I read your other post. Your winter mode will start you out in 2nd gear. So you will want to stay away from that. EC tune does not do anything with the W/S mode. You should not be getting all this bucking you are talking about with or without traction control on or off. Make sure you didn't unlodge the throttle peddle from it's mount. If you did, this will limit your throttle peddle's movement. It slips onto a flat piece of metal. I can't imagine you having a throttle body problem, and you stated in your other thread you have replaced the pump before. Only thing left would be fuel. Check that throttle peddle....you really have to get under to see...if it is mounted properly.
Chuk. I don't have a EC TCU tune. I may have misspoke. Do they do a manual mode on their tunes? Still wouldn't be his bucking unless he isn't controlling the throttle from all that instant throttle. They can buck. But it would not lose power. My tcu tune isn't like that.
Well, just trying figure out his problem. My TCU tune was just to match up with the 3:46 rear end. But I will keep that in mind lol. His problem sure sounds like an inner cooler pump but says it has been replaced. I had my throttle peddle comes loose from the mount which limited my throttle...took a little bit before I figured out what was wrong. Thank Chuk...
I've tried it in every conceivable configuration, and it's always the same. Buggin suggested that I check the fault codes, and I forgot that it had an OBDII, blue tooth module in it so I downloaded Torque and it was showing a P0410, Secondary Air Injection Code. I just got home, so I haven't researched that fault code yet. Thanks for the response.
Thanks,
Berries, I thought maybe that would help. Is there any potential that when I had the throttle pedal out to remove the carpet, something came loose on the Sprint Booster. I have one in my other coupe, set on the sensitive setting and it's touchy, but I like it. The one in my race car is set on the slower, less sensitive setting. I've never installed one, just inherited them from previous owners.
Thanks for the suggestions guys. I read in another post that removing the 40 amp fuse, F4 in the fuse block under the hood would disable the traction control, so I tried that, and it made no difference at all. Unfortunately I think I checked the fault code when the fuse was out, so that may have contributed to the P0410 fault code. I'll check that out tomorrow.
