Car will not start
on
Re: Car will not start
THANK YOU for that input I will do that....
on
OK, found this thread ( https://www.crossfireforum.org/forum...em-module.html ), check post 44 from 180. There are earlier posts that mention that company that can fix/repair the skreem module as well (make sure it IS the skreem module, for sure). The text for a POSSIBLE reset of the skreem is:
Turned the key with battery disconnected to drain the capacitors. Then connected battery, turned key to on position for several minutes, sounded like things were reprogramming themselves, then turned key off for one minute. Then started car as normal.
I found this in the list of fixes listed by 180 on that link above. Credit given to whomever found this possible fix. IF the RESET try does not work, then you might have to send it out (less expensive) if you have determined the skreem is the problem. The company is also mentioned in the link above, and in the .pdf listed in 180's list of .pdf's. GOOD LUCK!
on
on
Rob at Needswings now has the SKREEM and halo ring for $229.95 PROGRAMMED to your car !
NeedsWings Performance Products. SKREEM and Antenna Ring
NEWSFLASH !!!!
on
Well I have done a lot of reading and tried reset the skreem but it just does no good same thing motor turns over and starts but as soon as it starts it dies and I can do this 3 times than nothing and than discount the battery than I can do it 3 moored times .... I looked up on Needwings web and rob does have a new skreem for a far price but I'm not 100% that's what is wrong ??? Any Moore input would be great ???
3 strikes and you're out, then reset retry same thing, SKREEM.
on
I'm not really sure on this, but the rumor is that after 30 times ( and I'm also not sure if the 30 is attempted starts or the number of resets done ) the BCM ( Body Control Module ) will do a Mission Impossible and self destruct.
I have never seen a post where someone verified this and had to replace the BCM.
on
on
I'm going to replace the skreem myself so I was looking for a how to replace skreem but could not find it ? Does it have another name or ?? I did look at the helpful stickys but no step by step that this old man needs ... any help on where I mite find a step by step ??
on
There are (the usual poor) instructions in the service manual. The SKREEM is sitting behind the gauges, taking the dash apart is not as bad as it sounds.
There IS a thread here where a guy did it and posted photo but i can't find it.
One more thing, you should have this as a bookmark on your computer:
