Wheel cleaner
on
Re: Wheel cleaner
WOW! That did the trick and looks great! Aren't you missing a couple lugs though?
Re: Wheel cleaner
From what I can find on the Kaboom website (assuming I'm looking at the correct product) it looks like this cleaner is a high alkaline cleaner (pH of 12), which isn't all that different from Meguiar's Hot Rims All Wheel & Tire Cleaner. Out of curiosity, you said you tried two different wheel cleaners before Kaboom but neither worked - care to share what those two wheel cleaners were? Also, was this accumulated and embedded dirt just in that bottom section of the wheel after sitting on the back of the CR-V for a few years?
Re: Wheel cleaner
Mike, I tried Armor all, and Mothers. They didn't touch it. I tried the Kaboom only because the Honda is not quite as rare as the XF, lol. The crud on this wheel was the same all around. But ONLY on the spare. Maybe the P.O cleaned the wheels on the ground, but never touched the spare? Maybe the spare had the cover on it for years, and never dried out? The P.O was pretty meticulous about things. The engine compartment looks like brand new.
Re: Wheel cleaner
Guys, if you have baked on brake dust I've found that non of the commercially available cleaners work well. I recommend Poor Boy's World brake dust cleaner. It really works wonders. Just spray it on, and hose it off. I let it sit for a few minutes, and I did use a brush, but when I sprayed it off with water, it all melted away.
http://www.poorboysworld.com/spray-rinse.htm
on
Re: Wheel cleaner
For the heavily caked on dust that nothing else seems to touch, try Easy Off Oven cleaner. Sprays on and wipes right off. Just make sure there's plenty of ventilation!
Then to get that final clean use a clay bar made for wheel rims. A thorough waxing and you're good to go.
Re: Wheel cleaner
But is it safe to use on SRT6 clearcoated rims?
on
Re: Wheel cleaner
Why Sowtenly. I used it on mine. Just don't leave on for any great length of time and rinse off thoroughly. The wash bay boys at the dealerships use acid (yes, acid) to clean extremely caked rims. They just make sure to rinse them immediately, and then soap down and rinse again. The lye in the oven cleaner isn't quite as harsh as the acid wash. But neither seems to harm the clearcoats.
on
Re: Wheel cleaner
Here's how you can make your own wheel cleaner for 10 cents / qt.
Mix 32 oz water and 1-2 tablespoons of Bar Keeper's Friend (the powdered stuff you get at Wal-mart, like Comet & Ajax)...you can store this in an empty spray bottle. Use as needed and apply with a wheel brush to maximize cleaning efficiency. Many wheel cleaners contain Oxalic acid, which is the active ingredient found in Bar Keeper's Friend and is very much safer then the Hydrofluoric acid used by dealers. Even does a nice job cleaning & clearing hazy headlight lens and removing stubborn spots on windshields. Now you don't have to get ripped off by paying $5-6 for a bottle of wheel cleaner!
ritous1
09-26-2015 01:27 PM
