Adjusting headlight assembly as a whole unit
Old 12-21-2014, 05:23 PM
RyansXfire's Avatar
Default Adjusting headlight assembly as a whole unit
OK, so I changed both low beams a couple of weeks ago. Now the drivers side low beam will not adjust high enough. I'm sure the bulbs are in correctly. I've actually shimmed the top of the bulb to get a little distace. Any ideas anyone?
Update: the suspect bulb died on the way back from Charlotte last night. I swapped it with a spare I had and like magic, after a quick adjustment they are now spot on. After comparing the 2 month old bulb (would only point down and more down) with another known to "aim fine", the suspect bulb was found to have manufacturing issues as the bulb is mounted not quite perpendicular to the base. Never had a bulb with this kind of issue but I guess there is a first time for everything.
Last edited by RyansXfire; 12-24-2014 at 09:07 PM. Reason: Correct information/update with solution.
4drturbo
21
11-12-2018 04:50 PM
smokey847
11-12-2015 11:54 PM
stlas69
09-14-2015 06:45 PM
xjken
09-13-2015 10:18 PM
jaesa
09-07-2015 01:50 PM
Quick Reply: Adjusting headlight assembly as a whole unit
