Light Concern #2
Light Concern #2
OK, I noticed that my "Brake Lights" are always on, when running the Crossfire with lights on. When I don't have my lights on they are off and run correctly. What would cause this, Brakes are in great shape.
Even the Roadster trunk light is always on. I usually run the Crossfire with lights on for safety, but I don't want one of the idiots in the car world not to stop in time. Suggestion would be helpful to fix the problem. Yes I know don't drive without the lights on is a solution, but I would like to drive with them on. A short somewhere?
Thanks for the help ahead of time.
Re: Light Concern #2
Wrong bulbs have caused problems before.
AND . . . you never bothered to post and tell us the outcome of your other recent cry for help . . .
https://www.crossfireforum.org/forum...tml#post834023
Posting the resolution to your problem allows the forum (members) to assist others posting a similar problem in the future.
on
Although this post is not specifically aimed at this OP, it pisses me off members don't follow through and AT LEAST have the courtesy to follow up and post if the problem is fixed. I might have been guilty myself, those better at searching may find one or two. I say now if you do find one, I'll step up and follow up. I sometimes suspect dealers register and ask troubleshooting questions to repair problems they have before selling the XF's they take in on trade. Users, in every level of society. Oh well... Rant over!
OK here is the answer. When driving down the road, without my lights all on, the Brake light was working fine. But if I turned on the lights (no matter what light was on) the Brakes lights in the back were constantly on. It was like I had my foot on the brakes all the time.
Had to replace the Part # 5098638AA which is a Module for the Lights. $496 worth. According to the Mechanic the mother board inside to a dive. Had to replace the entire module.
3 hours to replace it. Running fine now...so much for the tax return. And yes this was a MOPAR part, not a MB part. (49000 miles)
Thanks for all the information. I appreciate it.
That is not a Mopar part, the part number molded on it is (US version) #193 545 00 04 (click for picture). The 193 number means it was designed and made specifically for the Crossfire but it is a Mercedes part, the Mopar part number is not molded into it at all, there may be a paper label with that number on it but that is all.
This part is the light switch and fuses associated with it are on the side of it, in the manual it is called the Illumination Control Module.
The actual part was purchased from Mercedes and a generous mark up applied to it for the Chrysler profit margin. During that time a Mopar label was stuck over the Mercedes label, that label cost you a fair bit of money.
I and many here could replace that module in under an hour, maybe thirty minutes if we did not stop for a coffee. I have sold two of those parts on this forum for less than $100. They are regularly on eBay from $100 and up.
It's a pity that you did not come back to the forum for some guidance before parting with the money.
velociabstract
28
10-28-2015 12:46 PM
dbooso
08-27-2015 11:03 AM
glover
08-23-2015 05:07 PM
