Climate control blows warm air, A/C is fine
Re: Climate control blows warm air, A/C is fine
I'm back. I did the Heater/AC Fan Speed Control fix. I've given it a week and although it worked a little better the situation never fully resolved itself. The next step was to check the blend door. I removed the plastic cowl below the windshield and noticed the door was in the closed position. I gave it a little push and it opened. I then turned the car on and started the climate fan. I next hit the Rest button and watched the door close. I then turned off the Rest button however the door stayed closed. I'm assuming it should have opened up to allow fresh air in. Any suggestions?
The flap actuator is behind the glove box I think, that has caused problems as well.
Ok, I had a chance to look at the gray vacuum line under the battery. It looks fine all the way from the engine past the firewall and into the cab. No kinks, no cracks or holes.
To recap..
1) My cabin air always seemed to be warmer than the outside air,
2) even in 50 degree weather with the dials turned their coldest setting, the cabin air would always get to about 10 degrees warmer than the outside.
Fixes...
1) I thought it was the duo valves but they seamed fine.
2) I next tried the climate control mod suspecting it was a bad controls but that didn't help either.
3) I then moved to the blend door. Bingo! Its stuck in the closed position. That would explain why it's always warmer in the car since its in recirculate mode.
4) the gray vacuum tube seems to be in working order.
I've removed the cowl below the wind shield and turned off the REST button and pushed the blend door open. I then turned on the REST button, blend door closes as it should. I turned off the REST button and blend door stayed closed. I'm assuming it's not the vacuum because I believe the vacuum is what is need to close the door. My next move it to research the flap actuator under the glove box and get back to you all.
To recap..
Fixes...
You by chance wouldn't have taken pictures when you changed out the blend doors? I believe I have the same issue and would like to tackle this myself, but would like some visual assistance to help me walk through it..
Any help would be appreciated..
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Any help
Problem
2004 crossfire RHD not giving cold air on a/c mode ... normal cool air not cold
investigations so far:
a/c compressor is engaging and spinning fine
refrigerant psi level approx 40 , mid way of blue
air filter is clean
any advice what to test next ?
Problem
air filter is clean
I have a 2004 crossfire.
The problem is... The AC intermittently blows hot air (does not happen all the time) one day the AC works fine, some other day the problem comes up. When this happens, the driver side blows cold and the passenger side blows super hot. Sometimes vice-versa happens, if the passenger side is blowing cold, then the driver side blows super hot. NEVER does both sides blow hot.
Any fixes for this problem ?
on
on
Possible BUT, it needs a little more diagnosis to nail down if it is a sticking set of duovalves, or an erratic signal from the control head. That involves a little reading of the service manual to understand the operation of the duovalve 'pulses' from the head, and a voltmeter. trivikramc, did you have the A/C control head out recently, has this always been happening, please let us know these two things to rule out the two duct positioning pins behind the A/C head. As far as checking the duovalves, read some about the system operation, then set up a test for seeing if the valves are responding to the signal from the A/C head based on the driver and passenger temperature dials. Good luck!
"Why? He said it works sometimes, if it is working what would a change of freon do?"
GG- it's complicated; I had the same problem and my go-to mechanic/friend of 30 years fixed the problem. His background is in Mercedes, BMW, Ferraris, etc - he knows these vehicles well.
The a/c system has a very good filter, however, contaminants, water, etc can build up in the freon. The evac removes these, takes the water out of the freon, cleans and puts back the correct amount of freon (recharge)
This eliminated the problem. Certainly there are other components of the system that could malfunction but the example in this case was identical to my problem hence the advice given.
These are the things I have done.
1. Tested the duo-valve voltage at full AC dial-- 13.1 volts
2. Tested the duo-valve voltage at full heat dial- 8.3 volts
3. The driver side coolant hose going into the firewall at full AC-super hot
4. The 2 hoses going from the duo-valve into the firewall on the passenger side were warm but not hot
5. The fat coolant hose feeding the duo-valve on the passenger side is super hot
***The console climate control unit was not changed***
on
cfk, the A/C system is a completely sealed system, not complicated at all.. There is no way any moisture can get into the system. The only way is if there is a leak, and the OP never said the system was leaking or opened. I don't know what your mechanic did with yours, but with pressure on/in the system moisture would never get into the freon to contaminate it.
Hello Crossfire wellwishers,
I was told to drive around with full blast Heat dial for 30 minutes so that the duo valves will clear any clogs.
I did it tonight and my ac is working fine now.
I will watch this for about 10 days and see if the problem comes back.
(My problem was intermittent to start with. I will keep you all posted)
Thank you Ron.
Thank you Ron.
on
Thank you Ron.
Thank you Ron.
Thanks for coming in with the solution! Great it is working now! Have fun and expect a lot of stares from curious people!
My climate control has been blowing hot air most of the time independent of the temperature settings for the past few years. Turning on the A/C though does result in cold air coming out of the vents.
After reviewing this thread I have
All that said, I welcome advice. Thanks
- opened up the duovalve -- looks fine to me. (BTW those 5 screws require a Torx T9)
- checked the continuity of the two coils with a Fluke DMM -- both are 21.3V
- measured the voltage coming from the duovalve harness
Max heat: 12.8 V
Max cool: 13.8 V
My next step is to remove the A'/C heater control unit and apply the glue hack to the boards.Max cool: 13.8 V
Frankenmerc
15
04-17-2019 08:59 PM
ewaynec
16
03-04-2018 02:41 PM
