Key broke from key fob.
Old May 3, 2023 | 07:39 AM
Hutch65's Avatar
Default Key broke from key fob.
Do need to buy a new key and have it cut to make my car run. Or is there an easier fix. Dad is getting impatient thinking he can fix it himself. Lol. Love him to death but from all i have read it must be hard. Thanks. Newbie here.
Old May 3, 2023 | 08:12 AM
zip439's Avatar
Default Re: Key broke from key fob.
Need more information! Is the metal "key" actually in two pieces, or has the metal key become disengaged from the Plastic ?? THERE IS A LOT MORE TO THE fob THAN THE METAL KEY TO START YOUR CAR!!!!
Do you have two keys? It is easy to dig a really deep hole if you do not know what you are doing in respect to the FOB. You need to read this before going any farther: Key Fob info
Here is another link to many fixes for the Crossfire that has been compiled by Onehundred80 over the years; after clicking the Link scroll down the page and find the subject "Fob Repairs" Index of Crossfire Repairs
Old May 3, 2023 | 08:34 AM
Hutch65's Avatar
Default Re: key is broke in 2 pieces.
the key is broke from the key fob. The end of key is still attached to fob.
Old May 3, 2023 | 09:34 AM
Inside that FOB is an RFID chip that starts the car. Do not lose that FOB.
Old May 3, 2023 | 01:05 PM
NeedsWings's Avatar
we can make you a new blade and get it all back together, message sent
Old May 3, 2023 | 01:34 PM
exparamedic's Avatar
How did the key break?
Was it because it was hard to turn in the ignition like a STICKY KEY?
Old May 5, 2023 | 08:28 AM
zip439's Avatar
Hutch, I do not know if you are still around, but the metal key can be replaced by Needswings or a local locksmith who works on cars ignitions. If you go to a Chrysler dealership parts dept they can look up on their computers the "keycode" for your specific car. You will need to bring your title and driver's license as proof of ownership and it should be free. Just takes a few minutes and with that "keycode" a locksmith should be able to cut you a new key.
Using the info I provided above you can place the new metal key into your FOB. Good luck!
Old May 5, 2023 | 11:23 AM
Sucks to have a broken key. It may be best (if your not sure you can do the replacement) to send the key to one of the shops members recommend here in the forum, that replace the entire keys, that'll make a new key to install into the FOB. You might have to send the second key with it (if only one, do what Zip439 said about going to Chrysler for the key code). Under NO CASE, do you let Chrysler either fix the key or service the car!!! Good luck!
Old May 5, 2023 | 11:51 AM
Ronman's Avatar
Josh says there is no key code from Chrysler that a locksmith can use.
Old May 6, 2023 | 05:38 PM
I believe that database was lost/destroyed some three or four years ago, Zip.
There is no longer dealer support for replacement keys.
Old May 6, 2023 | 10:14 PM
zip439's Avatar
I was at the local Chrysler dealer Thursday and they gave me the key code. I was there to get the vehicles PIN, but the process is the same. I showed them my title to the car and drivers license and they looked it up on their computer system. Took about ten minutes in to out the door at the parts dept. and it cost nothing. It was Free. I got the key code, but the PIN was no longer in there system.
I must go into town again Monday afternoon, so I will stop at a locksmith who does a lot of work with car ignitions and see if he can make a key blade with that code I received from Chrysler. He won't be able to repair a SKREEM or make a FOB from scratch, but I'll see if cutting a key is possible.
Old May 8, 2023 | 03:37 PM
zip439's Avatar
Ronman, Josh was right. The locksmith is looking for a 5 digit number, but what i got from Chrysler was 16 digit, so he couldn't figure it out.
He does have a tool that allows him to decipher the code he can use from a door lock, but I suspect we are back at $200 + just to get a blade cut.
Old May 8, 2023 | 03:54 PM
Ronman's Avatar
Thanks for letting us know. Since they no longer sell keys or skreems they should give us all that security info so we don't have to tear apart the dash.
Or some other company should be able to take over for Mercedes since they don't sell skreems or keys to their own customers.
What was the PIN for that you were talking about?
DirtyDen8810
Oct 5, 2019 08:29 PM
russ1ell
Sep 17, 2017 08:16 PM
Larry Hitze
Mar 23, 2014 01:33 PM
blackcrossfire07
Feb 27, 2009 12:22 PM
WAR IN D
Feb 23, 2008 01:34 PM
