After winter time no start
Old 03-22-2017, 04:24 PM
Default Re: After winter time no start
Originally Posted by danulah
Today i change all spark plugs. Engine now start but only for max 2 second.
It is problem with IMOBILISER ?
Thank you for any idea.
Is it possible that two or more plug cables are switched to the wrong spark plug?
maybe if the firing order is wrong then the car will not start.
Old 03-23-2017, 02:19 AM
danulah's Avatar
No no, everything are ok,cables and possition of spark plugs
Old 03-23-2017, 06:52 AM
If it allows you three attempts to start, then you have to disconnect the battery and reconnect to try three more times, then, yes, it is most likely the immobilizer ( SKREEM ) module.
Old 03-25-2017, 05:42 PM
danulah's Avatar
Today engine start and car go go go
But..... if i turn key and start engime i must push food switch of power and stay 3000 (RPM) speed some time and step by step down and down 2000,1500,1000....and after 2 minutes released pedal of speed and engine run normaly without my legs and set up Drive go to small trip. After this parking car and shock dashboard blackout displays and engine dont start,central locking dont lock doors and manualy lock using swith in car too.
WHAT IS THIS??????????????????
Now car is not possible to start,dashboard nothing,locking nothing......
Old 03-25-2017, 06:41 PM
If you have access to a multimeter/voltmeter, measure between the positive battery terminal and some good metal point on the engine.
Do you see around 12.2 volts ?
If not, remove the negative battery cable from the battery and the fender well and check that there is no corrosion at the mounting point.
( I suspect you have a battery to ground (earth) problem. )
Old 03-26-2017, 12:08 PM
danulah's Avatar
Yes, i have multimeter and voltage is correct.
Now car stay up the hill and only light when take a key to ingnition is battery. Windows and seats are function,fuses are ok too.
But if the car stay on straight road display on dashboard all at once running.
Old 04-01-2017, 01:26 PM
danulah's Avatar
Unhappy Re: After winter time no start
Today was nice day. I try clear MAF sensor and fuse box. Dashboard and central locking working correct.
I try start engine but result is the same. Start and after 2 second stop, but if i push accelerator with starting and RPM goes to 4000 and step by spep going to idle car is preparing for trip and wonging so goo. But if i stop and switch off and after one minute try start it is not possible and i must same procudere with pedal.
Please help me i am at a loss
