Runnin without sensors.
Has anybody installed new tires without using the tire pressure sensors? I'm thinking about installing some aftermarket rims and tires, but I wasn't planning on installing the tire pressure sensors.
Besides the warning light staying on, will it affect anything else, such as traction control etc?
Thanks.
Thanks.
Re: Runnin without sensors.
Thanks.
Thanks.
Thanks.
Thanks.
Thanks everybody. Knowing how (I understand) the sensors work, I thought the ETC may possible use the sensor "info" to determine when one tire is spinning more than another one and make the necessary adjustments.
But, I suppose if there is no sensors at all to read, then even if the ETC was involved, it wouldn't make any difference since no signal is being sent.
The traction control uses a different set of 4 sensors. Those are referred to as wheel speed sensors or ABS sensors.
Originally Posted by MI1XFIRE
+fireamx,
Now if I can just come up with the money to buy em.
rampntlion
21
02-11-2019 08:18 AM
