tire sizes to fit your car
Old 04-11-2011, 04:59 PM
Default tire sizes to fit your car
I hope you can inlarge this so you can read it, #1 the factory size, ,, if not i can upload them to my photobucket then put them on the page.
this will tell you what tire will fit the crossfire either 18's 19's or 20's. your tires are 26.1 tall jim
×Crossfire1× (02-06-2023)
Old 04-11-2011, 08:21 PM
Moparrbust's Avatar
Default Re: tire sizes to fit your car
345/30 18's FTW
Old 04-11-2011, 10:10 PM
MikeR's Avatar
How big of a wheel do you need for that 345/30-18, 11 inch??? Holy cow! That is 13.5" of rubber on the ground!
Old 04-12-2011, 03:00 AM
12.0 is the largest u can fit under the fender 305 35 18 with a 9" rim with a two inch lip and 40 et.(offset) and they may rub,, but with a 9,10,11" rim with a 3 to 4" lip letting the tire stick out from under the car it would work. this is for the rear not the front.
Old 04-12-2011, 10:19 AM
MikeR's Avatar
Yes, but it is still a mind boggeling to think what that much tire would look like under the car when seen from behind.....
I will stick with a 285 or 275 when I wear out the 255 Kumho's..
Old 10-19-2011, 02:23 PM
can i put a 265/30/19 on the rear? any issues?? they dont have the stock 255 in the dws i want on tire rack..dont want to go huge with the rear since its been lowered..any help is greatly appreciated. thanks
Old 10-19-2011, 05:28 PM
Mike, Jim needs all the tire he can get....lol...
Old 10-21-2011, 10:37 AM
295/30/19 is the same diameter as stock rear. It's only 10 mm wider than 285/30, so if 285/30 will fit on the stock rim, so should 295/30.
Old 10-21-2011, 10:49 AM
295 30 19 should fit it is 26 tall 11.2 wide and will work on the stock 9" wide stock srt rim.jim
I just read my own post maybe that should be my new handle rimjim lol.
Old 12-21-2011, 01:58 AM
What is the biggest size wheel that you can put on the crossfire?
Old 10-12-2012, 02:18 AM
JEFASOLD's Avatar
Yes, 295's will fit the stock rim but it is not recommended. I put 275-30's and tire rack recommended at least 9 1/2 wide rims as a minimum so I am sure that you should have wider rims for 295's. Tire rack has a chart with each brand that matches tire size with min and max rim width. You have to be careful when purchasing wider rims to get the right offset. I also added .83 in spacers to widen the track width.
Old 02-24-2013, 10:55 PM
Was wondering if i could put a set of corvette rims on the car, the front rims are 18 x 8.5" and the rear are 18 x 10" will that work? and wht kind of tires would i have to run those rims?
Old 02-24-2013, 11:35 PM
JEFASOLD's Avatar
I don't think that the bolt pattern is the same.
Old 02-24-2013, 11:41 PM
Mrmiata's Avatar
Then you will also have to look at the offsets..
Old 02-25-2013, 09:04 AM
rayth's Avatar
nope, those have a 5x120 bolt pattern, you need a 5x112
Old 02-25-2013, 09:35 AM
There are several online resources for 5 X 112 to 5 X 120 wheel adapters, but be warned that most are 1.25" thick ( 31.75 MM ). I did see one listing at 15 MM, but that is probably pretty near the limit on strength.
At any rate, you will be looking at additional wheel offset, so make sure what you intend to install will fit.
NOTE: This is for information purposes only, IMHO this is NOT a good idea.
Old 02-25-2013, 12:29 PM
Thanks for the help
Old 03-14-2014, 05:05 PM
i checked the chart, but didnt see a 17 inch rim.
Can a 225/60 r17 work on the front and back?
Old 03-14-2014, 06:33 PM
Speedy4x4's Avatar
225/60r17 are about 1.5" taller then ours but with a narrow tire on the back u will prolly burn it off. not to mention skiny tires would look bad on the back. just got my 275/35zr19 G-max's mounted on today
Old 03-14-2014, 07:56 PM
if you really want to use a 17" tire here is the correct one for our car.
stock front is 225/40-18 @ 8.9 sw,,3.6 h,, 25.1 tall
the rear 255/35-19@ 10.0sw, 3.5 h , 26.0 tall
the 17" to use is front 205/50-17 is 8.1 sw 4.0 h 25.1 tall or 225/45-17 8.9 sw 4.0 h 25.0 tall
for the rear 255/45-17 10.0 sw 4.5 h 26.0 tall or 215/55-17 8.5 sw 4.7 h 26.3 tall
for a wider rear, 285/40-17 11.2 sw 4.5 h 26 tall
I am running 285/35-19 ,,11.2 sw 3.9 h 26.9 tall, hope this helped you ,,
Oh This is the third time i posted this info on high of tires that will fit. jim
Edit: the 225/60-17 is 8.9 sw 5.3 h 27.6 tall it will not fit into the wheel well.
Quick Reply: tire sizes to fit your car
