Can some please explain in detail how the feibi camber kit works?
I was recently in an accident and I have paid 3 different alignment shops to adjust the camber on the front of the crossfire. NOBODY knows how this kit works! Can someone please explain to me how these little bumps on the washers adjust the camber?
I mean like a "special needs explanation", so as I can teach an alignment tech exactly what to do.
3 places that say, that bolt doesn't do a damn thing and this kit looks like what is already on the car.
I would buy the KMac kit but I think the feibi kit has to adjust something, somehow, or NW wouldn't sell them. So what is the deal???
Last edited by mobilefitt; 03-30-2016 at 10:46 AM. Reason: cleaned up some phrases
Re: Can some please explain in detail how the feibi camber kit works?
the adjusting bolt has a grove in it,,, , when you install the bolt it can go in two ways one is the stock position reverse the bolt and the grove in the bolt fits into a arrow . the arrow is only on the front of one side and the rear of the other,,, you pry the bushing arm back or forward to move the arm to get the alignment
you see the grove is only there for most of the bolt
below you will see A & B is the car and 19c is the bolt and it can be moved back and forth if the bolt grove is not lined up then the arm will not move make sure the bolt is facing the right way because if in backwards, it will NEVER get the alignment correct. jim
just found another pic ,it shows stock on the left and adjustable on the right. set to the left ,turn bolt over set it to right.
