Brake pedal travel
Re: Brake pedal travel
Hi. I did not bleed the brakes. Pushing the calliper pistons back in I assumed that no air would enter. I merely took the cap off the fluid reservoir to allow fluid movement, which did rise as a result of the newer thicker brake pads. Do you think air could have been entrained somehow and that bleeding could rectify the problem?
Bleed the brakes. It's the easiest / cheapest first step and likely the fix to the issue. I had same issue and bleeding the brakes fixed the problem. Good luck.
eelya1 (12-29-2022)
eelya1 (12-29-2022)
eelya1 (12-29-2022)
eelya1 (12-29-2022)
did bleeding the brakes work for you?
someone suggested replacing the brake lines as the rubber can get spongy
it was suggested that they be replaced with the steel mesh re-enforced version
on
I have the spongy brake issue too, on an 06' that i just bought with only 20,000 miles on it.
If that does not do the job, then you can look at other issues, like replacing brake lines - but IMO, there is no reason to go to the re-enforced lines, just replacing old lines should do it.
THis reminds me, in the new year, I think it's time for brake lines and hoses on my car. Fifteen years is enough.
eelya1 (12-29-2022)
If anyone is going to change over to braided stainless brake lines here's the part # for stoptech front 950.35001 rear 950.35500 changed mine a few years back, good quality price around $100 front & rear
https://www.partsgeek.com/ss/?i=1&ssq=950.35500
eelya1 (12-29-2022)
Bleeding the brakes is easy and cheap - just do it.
My tip is to change the fluid and bleed the brakes.
eelya1 (12-29-2022)
onehundred80
27
04-26-2018 10:41 AM
Turbo-Duck
04-03-2018 03:39 PM
