Old Jan 18, 2026 | 10:55 PM
M60A3Driver
Default Re: 2004 Crossfire Engine Shuts Off
Originally Posted by rubyl0926
Thanks for your response! I will give that a try. It takes 2-3 minutes before it starts up again. Should I still replace the Fuel Injection Throttle Body?
Again, thank YOU!
I think James is correct. You should start with the Relay Control Module (RCM) and the Crankshaft Position Sensor. You should always carry spares of both of these items.
I would suggest buying a new one and installing it. Then I would send the old one to @tighed1 to be rebuilt. He rebuilt mine about 2 years ago and it's better than new and was around the 60 dollar range.
These are the most common trouble makers on our cars.
Here are the posts I did for replacing both. The part numbers for both are in the pictures.
LINK - RCM Replacement
LINK - Crankshaft Position Sensor Replacement
