bblanchard33
CAN B Bus (+) Circuit Failure, Test 3. Measure the resistance between ground and the CAN B Bus (+) circuit at the CLP/SSM harness connector. Is the resistance below 10k ohms? No >> Replace the Central Locking Pump / Security System Module. I was unable to get any resistance reading from the Multimeter.
If you got no reading, then the resistance is over 10,000 ohms, that is for sure.
