Old Mar 29, 2014 | 09:34 AM
  #39 (permalink)
Mrmiata's Avatar
Mrmiata
Default Re: New Member - finally got another Crossfire!
This is not true.
If there was two parts with different plugs they would have different part numbers.
The parts to which you are referring are two different parts each with their own part number.
The part number needed in this mod is given in the following PDF as is the O-ring part number.
Without the larger MAF the throttle body mod is probably not worth doing and the tune a waste of time until the MAF is fitted.
PDF
Whatever you say 180 ..
https://www.crossfireforum.org/forum...tml#post754112
