Old Nov 6, 2014 | 07:44 AM
Mrmiata's Avatar
Mrmiata
Default Re: Automatic Headlights
Originally Posted by Nokke
Thanks for Your reply. I'm looking only possibility to get normal lights turn on automatically when car is running. No need to work with brightness..
Or I was thinking that DLR's turn on automatically allways when car is running and other lights manually..
So, I'm just finding out, is these possible to make with low costs
"Automatic" DRL's - yes.. there is a terminal in the fuse box by the brake master cylinder that is "key on hot".. I'm planning on adding a Normally closed relay to the DRL's I'm adding that will open the circuit when headlights are turned on.
