Old Jul 15, 2015 | 09:26 AM
  #871 (permalink)
pizzaguy
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Sunburn
Completed the fix and the key turns great. Thanks for all the instructions and pictures. The issue I now have is the key warning buzzer stays on after I remove the key. I read all the posts and noticed a couple others had the same issue. Was there any clear cut solution to this issue? Thanks.
There is a switch in the assembly that, once you pull the key out, a springloaded actuator toggles the little switch that indicates to the system that you have removed the key. Sounds like it is hung up OR the wiring to the switch assembly is not seated well on the back of the switch.
