Old Jan 27, 2016 | 03:38 PM
pizzaguy
Default Re: $2,230 To Replace O2 Sensors?
Originally Posted by rampntlion
Looking for the most cost effective and least time consuming way to replace O2 sensors. Ideas?
Just moved to a new city (and state), my 'Check Engine' light came on, went to a garage for diagnostics and it reports that all four O2 sensors are bad. The garage contacts a Chrysler dealership which quotes the parts at $588 (each) for three of the sensors and $462 for one of them. That's $2,226.
I turned to Ebay and other sites and am finding sensors for between $20-$130 a piece. Any input on if these low-priced sensors are legitimate/adequate replacement parts would be much appreciated. I am looking to fix this issue on a budget.
Those are not low priced sensors, the ones thru the dealer are RIP OFF PRICED. The next time someone goes to Chrysler for parts for your Crossfire, know that this is a sign you are talking to the wrong shop/garage. Come here and ask us first !
THe car was built with mostly Bosch sensors, and they are not all that expensive thru German Auto Supply, autohaus in Arizona or Needswings.com. Rob at Needswings should often be your first stop - but the others can be helpful. Keep in mind that various items from the 2003 SLK320 are the SAME parts as on your car and they are usally priced way below even aftermarket Crossfire parts. Check with us first, and we can steer you right.
I have read a good amount of the threads on the O2 sensors. I don't have the money or time to buy a OBD2 code reader o...
Keep reading - cause you missed something: A code reader is a MUST HAVE - and they only cost $20 to $80 - go get one!
