shyloe
Can you possible be a little more specific on where to find this fuse? I am not really a mechanic (ok not at all) and I am stuck at work. I also read I could maybe remove fuse #9 if this is a SKREEM issue but have no idea where that is either
Under hood fuse box by the brake booster.. "should" have a card insert mapping the fuses for you..
And fuse 9 has nothing to do with a Skreem issue.. Great for a wailing alarm module or if your tired of overhead lights and fob functions..
And.. if I recall correctly.. about 30 minutes with the battery disconnected.. turn key over to run position.. turn key off and reconnect battery has worked a time or two.. Basically fully discharging the electrical system for a "reboot"..
