Old Aug 4, 2020 | 11:03 PM
pizzaguy
Default Re: 05 Crossfire Base Multiple Issues (Driveshaft, Trans, ABS Etc.)
Originally Posted by mikemadeit94
Took a look at my relay control module just for the hell of it, all the relays are in excellent condition, none closed or burnt, solder joints are strong but still decided to touch up the 3 that cause the start problems while I was there.
1) Noticed someone replaced this fuse with an abnormal size, going to replace do to the top not closing.
2) Is this the ABS module? It seems to be mounted differently then pictures I’ve seen online also some strange jumper wire coming out of the harness?
1) That fuse has nothing to do with the top, that is the engine cooling fan fuse.
2) That is the Fan Conttrol module, it operates the engine cooling fan and is powered by the fuse you mentioned in 1 above.
