Old Aug 4, 2020 | 11:07 PM
pizzaguy
Default Re: 05 Crossfire Base Multiple Issues (Driveshaft, Trans, ABS Etc.)
Originally Posted by mikemadeit94
1) I had the battery checked and it tested okay, I also tested the battery with the code reader and it turned out fine as well as the alternator. 2) Anyone know how to trouble shoot a dead abs module? 3)Also if the duo valve checks out should I attempt this fix to my climate control module https://www.crossfireforum.org/forum...speed-fix.html
1) You had the battery checked and it "tested ok"?
Wrong. Replace the battery. NOW. "Testing" the battery (for the purposes in this thread) is a waste of time. It's late and I've got to get to bed, I"m not going to type out the explanation - trust me, trust us, REPLACE THE BATTERY - it is the cheapest diagnostic you can run. If the cost of the new battery bothers you, ask yourself how much time you can get at a garage for the $150 the battery costs. Maybe 1 1/2 hour. YOu could screw around chasing all these issues only to find out one or more is the damn battery.
2) If the ABS module really has gone bad, it must be replaced.
3) It may come to that.
