Lonroe
To my fellow members I am new to this, and with that said, I took my 2004 crossfire to the shop with a clutch problem (the Patel went straight to the floor,)after sitting for 3 months. I was then told some hours later that I need a flywheel (that they can't find) and a new clutch kit. Oh my...
also the flywheel would cost $17-2,300 and the clutch kit 600+. Do anyone have any info on a flywheel new or used?
The clutch pedal going to the floor is not related to a bad flywheel. If it worked before sitting for 3 months, you probably need to bleed the slave cylinder or look for a leak.
If your flywheel and clutch is bad you certainly would have known it before you parked it.
