Old Dec 31, 2021 | 10:33 PM
pizzaguy
Default Re: Dash lights go crazy, stuck in first gear, BAS light on and off
Originally Posted by Bzak1pgh
P0335 & P0600 All lights, like battery, seat belt, engine light, etc....but the BAS ESP will stay on until we restart the engine. Everyone of them will come on and go off, like flickering on and off the entire time until....again....a restart then all stop. RPM fluctuates where u can here it and feel it in the power, like if it raises u hear it and if it lowers u hear it but also feel the power difference too if that makes any sense at all....lol. but I'd we come to a stop the car will stay locked in 1st gear and if luckily it shifts to second, it will be stuck there in second...until again....restart then it's fine for a while...
This is not a wheel speed sensor.
P0335 usually means a bad Crank Sensor.
But the P0600 is another matter, it points to failed communications between modules but does not tell us which modules, you can assume it's failed communications from the ECU to another module.
Given the lights coming on like that I'd suggest the following:
1) Replace the Crank Sensor with a Bosch part from German Auto Supply, FCP Euro, etc.
2) Replace the RCM or send it to DJ for evaluation (he will replace bad relays and reflow any suspect solder paths).
3) I'd take a REAL close look at battery post connections, and the ground from the block to chassis or maybe install one of these modifications:
https://www.crossfireforum.org/forum...le-engine.html
I get the idea you have failing power to the ECU/Brake Controller/TCU/Instrument panel, this can be in the RCM or in the electrical (battery/alternator) system in general.
