eelya1
maybe it's because my key is stuck in the ignition... as i stated earlier, key in the ignition will turn but will not start the car
1) OK< so the key is stuck and you cant remove it, but when you do turn it, the car won't start? This is a bit of a new one.
When you say it won't start, does the starter engage and spin the engine or not?
2) As to the key not coming out of the ignition, that is an indication of a "tumbler jam" or that when you are turning it to "off" you are not turning it all the way to "Lock" which is where you can remove the key .
One way around this, is to:
Turn key to off.
Disconnect the battery.
Using the "sticky key" (old version) instructions, turn key back to "on" and use pliars to remove the key/tumbler combo.
THen you can get in there and figure out whats' going on.
Since you are in Charlotte, if you don't wanna mess with it, let's get Zach to come up and fix this for you. Not sure what he'd charge, but the kid can fix ANYTHING. He can also look the car over and help you address other issues that he may see as a problem, before they become a problem.
I will contact him and ask him to check in here.
