Old Jan 3, 2024 | 02:13 PM
  #69 (permalink)
pizzaguy
Default Re: Help diagnose intermittent rough running
Originally Posted by bc75
Still getting the rough idle and no codes. Yesterday my fuel light started flashing. When i got home ran codes and got P0455. I've replaced fuel cap, fuel pump and purge valves already. When it warms up i think I'm going to pull the vapor canister. See if anything is broke or has a hole in one of the lines.
The 0455 means there is a leak so bad, that when the evap system tries to pressurize the tank for the evap test, it cant because SOMETHING is bleeding the air out just about as fast as it is pumped in.
WARNING: Do not overlook the chance that the tank is pressurizing fine, and the SENSOR is bad, lying to the ECU.
You can work to "fix the leak" all you want to, but if there IS no leak, you are wasting your time.
