Old Mar 31, 2024 | 03:47 PM
pizzaguy
Default Re: Alternator issue or something else?
Based on what you have said, are you referring to the clasp on the Neg battery terminal?
I took it to mean the stud on the chassis was loose, making the ground connection really bad. But he has the redundant ground fix that James recommended and invented - so you'd think he'd be almost OK.
IF he meant on the BATTERY post, that would mean the redundant ground could not even to it's job - and would explain it all. I did not read it that way, but it would explain things rather easily.
