Alternator issue or something else?
Old Apr 12, 2024 | 12:11 PM
Default Re: Alternator issue or something else?
Originally Posted by Ronman
That looks like a Chrysler sticker. Did you buy a Chrysler one instead of a Mercedes one that is usually less expensive????
I have found on some occasions that the straps that stick out the side through which the bolt goes through gets distorted and will be touching each other before the bolt is even tightened. It is a soft lead and easily bends, I just wedge a screwdriver between the straps and separate them and it now clamps. Using too much torque when tightening the bolt causes this to happen .
Keep the contact faces clean.
Old Apr 12, 2024 | 12:27 PM
How ya been, Dave? Iv'e not seen a lot of posts from you lately.
Old Apr 23, 2024 | 01:56 PM
crobards's Avatar
Hi All!
I just wanted to give an update on this situation. After following the guides you all provided, everything was within the specs in terms of battery draw.
As a last resort. I ended up returning the “new” battery and swapped it at another autozone location. Turns out, I was sold a 2 yr old dying battery. They replaced it with a newer one which was manufactured last month.
It has been two days and the car starts no problem. I wish I did it sooner. If anything I gained more knowledge in the electronics part of the car so I take the loss with a win.
Thank you all!
Old Apr 23, 2024 | 02:59 PM
Yes, everytime I hear it is a new battery I always say, do a draw test on it. New does not always mean "NEW".
Old Apr 23, 2024 | 03:12 PM
This also illustrates why I preach: "Replace the battery first, then do your other diagnostics".
Old Apr 26, 2024 | 10:30 AM
I sometimes find some of the stores that sell batteries, all they do, is stick a current or past month little round colored sticker with the month/year on the top or sides. These stickers are supposed to indicate they 'serviced' and 'charged' the batteries on the rack per the suggested charge cycles depending on the batteries pre-sale care instructions. Labor intensive & with records upkept, for the volume of batteries sold..
wld1985
34
Dec 25, 2024 02:56 PM
mp3wizard
Sep 5, 2010 12:54 AM
livefreeordie
Aug 7, 2010 10:33 AM
KROSSFIRE1988
38
May 4, 2010 04:54 PM
vinny186
Nov 16, 2008 06:58 PM
