Old Feb 19, 2025 | 01:09 PM
pizzaguy
Default Re: Crossfire convertible trunk question
Originally Posted by Sleepysempai
If I could see what the trunk light connector looks like it might help me out since i couldn't find that connector. It could possibly explain why my OBDII says the trunk is always open.
1) You are making assumptions that are wasting your time. The "liftgate" sense is pin 13 of connector C1 on the CLP/SSM. This tells the security system that the liftgate (trunk) lid is open or closed. This pin does NOT control the trunk light.
2) What year is the car?
2005-2006: Trunk light is wired to the interior light circuit (dome light), not connected in such a way that the ECU knows that the trunk is open. There is a separate switch that drives the "trunk open" indication.
2007-2008: This one is unknown, I know the trunk light does not drive the dome light at all but I can't say exactly how it is wired. But it would in contrary to their designs for the trunk light switch to drive the CLP/SSM "trunk status" indication; not saying it is impossible they did that, just unlikely.
3) If you want to get into this, I encourage you. But you MUST get the service manual out and start going thru the diagrams so that you understand how the systems work. EXAMLPE: Being distracted by the trunk light being on is a rookie mistake that will waste DAYS of your time. I urge you to sit with the wiring diagrams and read - this will raise questions in your mind that you must clarify before proceeding. I've been here 15 years and I an still uncovering oddities - like I had no idea the trunk light wiring varied until I bought my 2007 Roadster and observed some differences that everyone said did not exist; all Crossfires are not wired the same, changes were made in 2007.
