Old Jun 10, 2025 | 10:30 AM
pizzaguy
Default re: Erratic Spoiler Fix - Limit Switch Source Identified
Originally Posted by Oldstrain
Well, you asked for a report….today I unearthed the CLP/SSM and it was as dry and pristine as the day it was installed.
Spoiler continues to operate semi-correctly only every other ignition cycle - I gotta believe that’s significant.
Any more suggestions? All appreciated.
Paul Brown
It is very hard to diagnose a car based only on what someone types on a message board. The very attempt is full of pitfalls and misunderstandings, again, based on the idea of troubleshooting a complex electro-mechanical system based on text on a message board - we can only do so much. SO:
First, owning a Crossfire without having a spare RCM is a mistake. Order one, put it in, and see what you have - you MUST have a spare in the trunk at all times or risk being towed home someday.
THey plug in and can be replaced WITHOUT TOOLS or any real skill set.
Second, if the car's battery is over 48 months old, if the battery cable clamps look horrible or are loose - FIX THAT.
Third, if you have not done James' mod, do it today:
https://www.crossfireforum.org/forum...le-engine.html
If the problem persists, we can go from there.
